Disapointed by RX350 AWD Snow Capability
#151
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
In scientific terms it is the coefficient of friction and the road-surface, tires and any medium in between (ice/snow/water).
Salim
#152
good comeback . . . the issue is one of inertia: a body at rest will not move - because only 1 front wheel spins (snow/ice). if it were a rear-wheel differential problem, i could apply the emerg brake lightly to transfer the load from one side to the other.
#153
The same can be achieved at the front wheels with careful brake pedal modulation.
The RX uses a open differentials front and rear. Only the F/R bias is really controlled by the computer, however 3rd generation RX models equipped with VDIM do have an electronic LSD function which will apply braking force to limit wheel slippage. Models without VDIM do not attempt to control L/R bias in any way (mechanical or electrically).
This came up previously in the thread and there was some question as to the effectiveness of this form of LSD. I've seen it used to some decent effect in off-road situations in vehicles like the FJ Cruiser, Tacoma, and 4Runner. On-road the IS F made okay use of it for 2008-2009 before adding an actual LSD for 2010. I am not sure on the exact engagement conditions for control in the RX, but based on my reading it seems to be used more for control through corners than in situations where only a wheel is spinning (from stopped or while driving straight).
Jeff
Jeff
#154
thankyouse ! one concentrated bushel of information you have provided.
gent commenting to his lady, "no idea why you wanted me to put the cake in at 120degrees."
she looking into the oven at the cake balanced against a protractor at exactly 120degrees, "GEORGE !"
Jeff Lange (01-06-20)
#155
I guess the moral of the story is don't be afraid to pay a bit extra on a better set of snows, you'll be thankful you did. I love the Hankook iPikes and the Blizzaks, both fantastic snow tires.
#157
Yes, it is. The 1 wheel spinning is due to the other 3 having traction and the 1 spinning wheel not having traction. The only thing between the rim and the driving surface is the tire. The fact that only 1 wheel is spinning is because the RX has open differentials both front and rear, and the path of least resistance is the 1 spinning wheel, where traction between that tire and the surface you're driving on does not exist. Change to better tires and you won't have nearly as much slip due to the improved traction = no path of least resistance.
#158
thankyou. specificially; if rubber was the true problem, with only one tire spinning, why would one other tire (RX - different differential) not also spin ? were two tires slipping, i would look seriously at the rubber solution.
with only one wheel spinning, i cannot. i believe the previous suggestion to use brakes to bind the spinning wheel to cause a load/traction transfer to be spot on. unfortunately, that was not attempted (then), so the solution remains only potential.
Dholmq
RX - 4th Gen (2016-2022)
73
01-24-18 06:30 AM
