FDToth's Odd Sound Thread
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Hi guys,
As i wrote many times, we have 2 Lexus Rx450h in Europe, Hungary . We bought them in 2010. We have problems with this sound since 2011 but nothing happens! Last time when we were at the dealer they show us a relly new 2013 RX450h, with 2-3 km, but in that brand new car, this cliking and rattleing noise is there! Lexus (or Toyota) sais that it is not normal but they can't do anything! They could changes the cars if any one of the new RX450h would be without this clicking or rattling noise, but they say all of the RX450h (In Euorpe!) have the same problem!
At our first car the brakes and the other parts of the brakes were changed 5 times!!! But it is worse than before! Now we have these sound on both cars:
It is a shame to park or drive reverse with these car! They are beeping all the time! Ervey poeppple on the street watch us while parking! This is not a premium car!
We had Lexus RX400h for 2 yeras it was such a wonderful car, but the Rx450h... These noises form teh brakes/suspensions,,,, they are terribel!
The dealer tries to solve the problem with many services but is is inefficent!
We can"t do anything!!!
(Sorry for my english
Regards,
FDToth
Regards,
FDToth
Hi guys,
http://www.youtube.com/watch?v=ImtGMSlWhLI
Regards,
FDToth
Regards,
FDToth
Has your dealer tried to grease the back pad with brake grease and the slide area?
The noise is almost gone for my 2011RX350. My wife drives the car daily. Today when she pulled into
the garage, I don't hear any noise.
This must be a known issue because my dealer knew exactly how to remedy the noise.
Here are a few pictures.
Hello all, getting close to finalizing a purchase of a 2013 RX350. Is this something I should worry about or is it just effecting a select few? I realize that a lot of time only the ones having problems post in these type of threads. Are there some with higher mileage that haven't had this happen? Thanks and this is a very informative forum!!
~Jeff
~Jeff
I used to work at a Lexus dealer in the 90s and we had the same issues with some of the models. Additionally, my wife's '93 Corolla used to make the same noise. The fix back then was to replace the hardware (fit) kit and lubricate the corners of the brake pad (not the friction material, but the "ears" that slid in the hardware kit). The clips that mount to the caliper bracket often did not have enough tension and allowed the brake pad to shift in the bracket.
FamilyRX
(coming soon)
FamilyRX
(coming soon)
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
One of our car makes this clicking noise more frequently than the other
Do you think that the sound on this video (applying the brake when the passengers get in the car):
Thank you
Lexus says that the abnormal noise from the brakes is there because of the developped performnce of the brakes. (and the clicking noise???)
In 2009, when the RX450h model entered the market in Hungary, there wasn't problem with the brakes and with their noise at the quality control. This could be true, cause our problems with the brakes (or suspension???) strated in 03.2011.
Lexus also says that they know this problems (construction failure) but can't do anything, hopeing that this noise won't be there at the next generation of the Rx450h... But these are not enough for many owners who have Rx450h 2009-
Thank you for the pictures!!! i dont remember that the dealer did it or not with the parts of the brakes. Our dealer don't do anything
We try to solve problems now with our lawyer.
One of our car makes this clicking noise more frequently than the other![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
http://www.youtube.com/watch?v=O7XsrAvUdBY
Thank you
Thank you
My 07GS350 does the same thing when I have my E-brake engaged.
So I brought it in for the dealership to check out. They said it's normal. Pads are shifting due to suspension movement.
Here's how to duplicate it.
1. Engage E-brake (in your case applied the brake)
2. Get in the rear seats (or bounce the rear end).
Then you will hear the noise.
Didn't hear any noise since they greased up the RX350 brakes.
I am curious, do you see the Slip indicator on a lot on your car?
I do have that noise, but much lighter noise and it happens only when I have my E-brake engaged.
My e-brake is not engaged just applying on the brakes and you can hear these noise.
Approx. 1-5, 2 yeras ago there was problems with the e-brakes, the dealer solved it with cleaning some parts.
I am going to try what you have written, but i havent realised yet noises when the e-break is engage
Slip indicator: it appears 1-2 times per month but just for 3-4 seconds, then nothing. if slip indicator ocmes on and "stays" there for a while - this is problem, but whn it flashes, i don"t hink so..
Hy Westyfield,
Just a general question: as the f-sport versions of the RX450h have different suspension/brake system, or 100% same as the "normal" RX450h?
On you vehicle, could you hear same noises like on these videos:?
When you get into the car (without e-brake, just applynig on the brakes)
Reverse, beeping noise:
and other two:
Thank you in advance for your answer,
Greetings,
Ferenc
and other two:
Greetings,
Ferenc
I would relly appreciate if you could make similar videos like we did, beacuse these could be a really strong evidence for us!
Thank you in advance for your help!
Greetings,
Ferenc
FDToth,
In your beeping in reverse video, is that your proximity sensors of the parking assist system sensing a nearby obstruction? Does the beeping stop when you put the car is park? Does it do it when some one walks in front of the car?
Is the squealing your brakes?
Here are some videos, exterieur, you can hear the same noise (no parking beep and without audio system)
Not as loud as on the other car:
Unitl 0:22 sec (exterieur, audio system and parking assist off)
Until 0:50 is interesting (extrieur, audio system off, parking assist off)
This beeping sound on the "almond brown" colour car is always there while forwarding, reverse just sometimes, it is random.
On the 'silver' car, there is beeping sund while reverse but as i noticed, 75-80% when the wheather is rainy.
Squealing from the brakes? Our dealer and the importeur say yes, but they don't know exactly, they don't do antything.
In this topic: https://www.clublexus.com/forums/rx-...low-speed.html chuckGS350 wrote me something how to solve it (page 2)
kaizmauka
12-13-17 12:29 PM
aliee
RX - 3rd Gen (2010-2015)
37
11-11-13 06:21 AM
1994 LS400
08-22-02 05:44 PM
