Clear Decals/Stickers Behind Door Handles
I just bought a gently pre-owned 2010 RX 350. It has clear decals or stickers behind the front door handles, but they are kind of dirty and I don't like how they look. Are these important for the smart access system, or just for keeping the car exterior clean with lots of handling? Can I take them off?
To clarify, the decals are not on the backside of the door handle, where the smart access sensor is. They are on the car door, in the indentation behind the door handle.
As many online stores as I've looked thorough over the years, I can't remember a source -- hopefully someone else will. Worst case, you could always buy some bulk XPEL or similar 3M protectant shield film, create your own template for the oval areas, cut them out and apply.
Joniwick/Emory2001 -- If you're going to detail your ride anyway, including new sealant or wax, have you tried something like IPA, "Goo Gone", or the spray "3M Adhesive Remover" on the problem area? The latter has never failed me in a tough situation getting rid of some little bit of sticky goo. Apply a little to an applicator, rag or microfiber towel -- a little rubbing, and voila! Just remember some of that is strong stuff, so re-protect (at least that area of) your paint/clearcoat afterwards.
...some good additional ideas in the Auto Detailing Forum here on CL. Good luck.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Using any of the products I suggested to get rid of the sticky stuff will effectively strip off carnauba wax and sealants I've dealt with (maybe not a coating) back to your clearcoat. Once you have the sticky stuff gone, I'd just go at the "re-protection" as if you have fresh paint and go from there however you do your thing with whatever products that may be.
I8ABMR
02-01-11 01:24 PM
