Can I switch from HID to Halogen?
#31
The wiring harness is not completely different. You can literally take the HID lights off the car, put the halogen ones on it and just plug them in.
After that, pull the AFS fuse to completely disable the auto leveling system and you’re done. If you want a more complete removal, you can take out the AFS ECU as well.
Jeff
Jeff
#32
I have had halogen, halogen with HID kit, the AFS HID lights (with and without STi lenses) and the 2011+ LED DRL HID lights in my car. It's all pretty straightforward.
Pinout:
Halogen:
AFS HID:
Jeff
Pinout:
Halogen:
AFS HID:
Jeff
#33
I need to get rid of my HID headlights for a couple of reasons that didn't seem to be addressed in this thread (even though the thread is correctly named). First, these HID headlights suck! I can leave my high beams on all night, every night, and NO ONE flashes me - they are that bad. Even with the foglights on, it's literally dangerous to even drive the speed limit on rural roads, for fear of outdriving my lights.
The body shop replaced that light with a new one, and supposedly "cleaned" the right one to make it look more like the new left one. Even then, they still sucked, and the left one looked just as bad as the right one within a few weeks of driving. This is a HORRENDOUS headlight design. LEXUS, YOU SUCK for ever selling a car with such dangerously crappy headlights!
Apparently one of the problems is that the HID lights also include "self-levelers" (which NEVER worked and are the stupidest things I've ever seen in a car - replacing a simply screwdriver adjustment
So what do I do?
1) Identify whether your replaced lamp is OEM or not. There is text in the boxed area. If it says "Koito" (among other things) then it's OEM. If it doesn't then it's aftermarket.
2) If it's aftermarket, replace with a OEM one. Like this one. Then you'll at least have one high-quality, OEM headlamp assembly that hasn't turned yellow yet, and since it's OEM, it's required by law to withstand 3 years of weathering--in other words, it shouldn't turn yellow/hazy for another few years. Unlike a typical aftermarket headlamp, which looks good rolling out the shop and typically turns yellow/hazy in a few months, because aftermarket doesn't care about the law (there's practically 0 enforcement in the aftermarket).
https://www.ebay.com/itm/2006-2009-L...YAAOSw38BaXP2e
You can use this eBay link to search for the other side's headlamp. I just typed in "is250 headlamp oem" and found plenty of results. It appears that your budget is $200 for both sides....that's a bit low...but you might be able to find some gently used OEM lamps that haven't started hazing over yet, which would still be better than most aftermarket parts.
https://www.ebay.com/sch/i.html?_fro...p+oem&_sacat=0
3) Philips XtremeVision H11 bulbs
#34
HID gs430
If you change the entire headlight to halogen it will just plug in and everything will work properly, yes.
The only thing you will have to deal with is the AFS light coming on on the dash. There is a fuse you can pull, or unplug the AFS ECU to disable that and at that point your car will function just like a car that came with halogen.
Jeff
Jeff
is there any particular brand of housings you’d recommend? I’m sick of staring at the ever-yellowing lenses of the HIDs on my Gs430. I would like to replace them with gs300 halogen housings and upgrade to LED bulbs, but I am skeptical about plastic’s quality.
#35
any update on your conversion to halogens? Did you replace the entire housings? I’m looking to do the same.
#37
sorry for bring this thread back after a few years. just recently purchased a 2006 rx400h and the driver side headlight assembly has condensation. the car has the Stock HIDs with the AFS. Driver side has a dying HID bulb or ballast. Passenger side seem to be working fine but the lense is a bit hazy.
have any of you folks gotten new halogen headlight assembly, remove the ballast, and installed halogen or LEDs? sure that i'll need to mess with the power from the ballast to connect to the LEDs.
as for the AFS, where is the AFS fuse or ecu?
thanks in advance.
thanks in advance.
#38
Jeff
Jeff
Thank for your answered. Could you please consult me on my case:
My Lexus 2010 RX350 original come with HID headlight assembly. Can i switch to Halogen assembly? if yes, how to re-connect the wire and plug?
Doober (10-01-24)
#39
The HIDs are worn out. Outdated, Also LEDs/Halogens now are brighter and more cost efficient. Thats why. Would love to swap out the HID headlamps with stock halogen or LED harness.
#41
Help please. Newbie!
Hello. I have a 2010 rx350 with 225k miles. I love this car and want to keep it. My drivers side headlight went out. Mechanic quoted me $2200 to replace ballast (I’m assuming the entire headlight assembly). It’s not the bulb, we already checked. I have the HID AFS system. Can I switch to LED by purchasing new headlight assemblies for both sides? Is this something I could do myself? I’m not handy but good at following directions. Also, if I can switch to led, does anyone have a recommendation where to purchase? Thank you so much!
#42
The ballast can be replaced I would not go back to that mechanic
https://www.japan-parts.eu/lexus/us/...101_headlamp/2
uncondition4l (05-19-24)
#43
That is a bad mechanic.
Clutchless (05-22-24)
#44
AFS fuse unplug
Jeff
Jeff
