iPod "Repeat", huh?
iPod "Repeat", huh?
13 Rx, love the iPod integration on the Nav screen.
I have been confused about one feature though....and the manuals did not clear it up. The manuals further confused me.
When you hit REPEAT, the vertical line next to REPEAT goes from yellow (and letters RPT appear above on the NAV), press again, the letters RPT no longer appears. It appears the only options are, RPT and the absence of RPT.
In the manual, for the Non Nav screen, it shows, 3 options, RPT song, RPT File and absence of RPT...this makes perfect sense. But I don't see the same 3 options on the Nav screen.... from experimenting, sometimes the RPT is for the song, other times, it's for the folder (playlist). Does anyone know how to distinguish when RPT = Playlist vs. Song?
Interesting, for album...
I listen to my playlist instead.....so if the same applies, is this correct....
the player will always repeat the playlist when it finishes, unless I manually change the Playlist?
and RPT means one thing only > RPT song?
You right on track... Whether it is the album of playlist should repeat until changed and if you press the RPT button, should repeat the track ...
jyeager
04-02-21 05:54 AM
