Dynamat?
Dynamat?
Sup RX gang! How many of you with a ML equipped RX have done this? I am seriously considering it because, I want a deeper bass and I cringe that from time to time, when my volume reaches over 35, my RX sounds like the video I made down below. The guys who have done this what is your review? Did it improve anything? Is it rattle free? Where did you apply it?
Thanks in Advance
-MjThind
P.S. The video is from a month ago, when I finally I got the garage space, and then my parents came back form there trips and now their cars are inside and my RX is outside...LOL
Thanks in Advance
-MjThind
No, I don't play soccer!
Take a look at this thread from MEP. I've wanted to do it to my RXh for a long time and recently talked to my installer about it. I forgot what he recommended. It was something other than dynamat. I'm still hesitating because I don't want my RXh ripped apart. Too many potential problems. If you get it done, make sure you let us know how it goes.
Retyping my post; must have not saved it...
I have added Dynamat to my IS in the doors and the rear deck. It works as advertised! I don't have a sub, but do have a good aftermarket speakers with nice mid-bass. The rattling is virtually eliminated, the road noise has been decreased and the doors lock with a more solid thud.
It is easy to DIY. The hardest part is removing the panels, but it is not that bad, especially if one can find instructions how to. Applying Dynamat is easy. Anyone with kindergarten project skills can do it. Just cut it to shape and press-on. Heat with a hair dryer if needed.
Just in case, I did take pictures of all of doors to be able to locate bolts, should anything need to be disassembled in the future.
Anita, I am with you.... ya gotta tear the rig apart, and then, how often does it go back together the same? Rarely. Some of the removable fasteners don't seem to work as good 2nd time, for re insertion. At least that is what I am finding. Although the appeal of this mod has me on the fence as well... I find the RX "sort of solid", but not rock solid like I expected, but not complaining due to mid tier price of rig. If this mod solved my mediocre ML sound system and made the rig quieter and more solid, like tinny sound when closing the doors, I would prob. do the mod. Of course, witnessing one already completed would push me off the fence, not sure what direction I would fall though :-) A qualified installer would be nice... I hate doing things for the first time...
Yes, installers are great. I had to find a new one when I got the RXh because my old one went into the home entertainment installation business. Much bigger bucks there. I was pretty upset because he also did body work for the local Lexus dealers. At least he knew the vehicles inside and out.
When I brought up adding dynamat to my current installer a few weeks ago, he said he wanted to do more than that because he didn't feel it was enough to make a difference. Ideally he would add a few things to bring out the bass. I told him I really wasn't interested in going down that road again after spending the extra money on ML and honestly would rather not mess with it. He understood and didn't try to push me. He probably thinks I'll change my mind.
I've seen the door panel removed from the RX before. It wasn't bad like vlad said but I still don't want to do it myself. I'll stick with the easier stuff.
OK. Doing the rear compartment with Dynamat (or similar product) is going to give you the best results. I did mine in stages and did the rear first. That is what brought the bass to life. The rear compartment pieces assemble back together just fine and I have had no rattling problems at all. I thought I had problems with the front door panels but it ends up it is the seal around the windows making the noise. I did do behind the speakers in all 4 doors and it did add a little more bass plus the doors are more solid when closing. So, if you are going to do anything, I recommend the rear compartment plus, it did help with some road noise.
