3RX Suspension upgrade
Hi,
Anyone think the ride is too soft and upgrade their suspension ?
Is there any kit out to upgrade suspension to sportier ride ?
Is there a tire with harder / lower profile side wall to make ride more sportier ?
Thank you
Thank you
No, I don't play soccer!
Welcome to CL, cupertino. It would be helpful if you provide more information like what year RX, 350 or 450h, 18"s or 19"s, tire brand, AWD or FWD, etc. There has been some discussion about improving the body roll in this thread. Or there's the F-Sport with its stiffer and sportier suspension.
The easiest thing to do is to upgrade wheels and tires. 19th will ride firmer than 18th. If the roads in your area are in a good condition, you can even be more aggressive. If you will never drive in snow, a good set of summer-only tires will give you a stronger sidewall.
thanks,
I have 2013 awd with 19s now.
area of driving: Highway 880 & 280. in San Jose area.
Can I just swap stock shocks with F sport shocks or more aggressive shocks ?
Running summer only/performance tires isn't the weak link in the chain here. I'm not really a Lexus fan (thought we would get the F Sport for sure, but really preferred the ride of the std suspension - wife coming from an Audi S) but it fits her criteria and I think Toyota did a great job with the vehicle over the years on several levels.
Just found this on Sewell Lexus. Has anyone tried installing these F sport dampers?
http://lexus.sewellparts.com/accesso...2013/6468.html
The price at LEXUS of SOUTH ATLANTA PARTS is cheaper that SewellParts.
Both front and rear are $ 473.69.
http://www.lexussouthatlantaparts.co...869148010.html
http://www.lexussouthatlantaparts.co...869148020.html
I had bought shark fin antenna from them before.
It appears that Dolphin only did the front because his Lexus guys told him the same thing they initially told me- a rear hitch isn't compatible with the rear damper. This isn't true. You would have to buy an aftermarket hitch, as I did, but it will only cost you about $140. It's on etrailer.com and fit perfectly. It has mounting sites specifically for re-install of the damper once the hitch is on. Ride quality did not change at all after the install.
I had bought shark fin antenna from them before.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
DANNYBOY
16
12-03-07 04:41 PM
