steering noise when turning or bumpy road
does anyone has the same issue? start the car, turn to steering wheel 30 degree to the left and quicky turn the steering to the right, i can hear some knocking sound from steering wheel or steering column, when i drive on bumpy roads, i can hear the rattle sound from steering wheel or column, anyone had the same issue? thanks
Yes, I have the same issue. If I am stopped, and I slowly turn the steering wheel to the left and then right, I get this creaking, knocking sound. This is a common issue on the HS250 as well and since the two vehicles came out at approximately the same time, I am sure they use the same steering column/parts. Best to let your dealer check it out, they can either lube it or maybe even change it out. I have yet to go, but my next oil change is in 2000 miles so Ill bring it up then
caha14
GX - 1st Gen (2003-2009)
16
05-12-05 06:25 PM
