10k service light?
Unfortunately the oil maintenance light can't be switched to 10K. Maybe the newer RXs will have this feature
The only thing you can do is reset it before the light goes on. It's simple enough, takes all of five seconds..
Display trip meter A, then turn power off.
While pressing the ODO/TRIP button, turn the power switch to on mode.
Keep the ODO/TRIP button pressed for about five seconds. Reset is complete when 000000 in the trip meter flashes once and the message in the multi-information display disappears.
I don't see an odometer trip button on the dash anywhere(only the controls on the steering wheel) and how do you turn the power switch to on mode since it only has the smart key? There is no ignition switch
Well, the answer to the original question has been found in the manual:
See Page 731
With your foot on the brake, press the start button. That will put the vehicle in the ON mode and will start the engine.
With your foot NOT on the brake, press the start button once. That is the same as ACC mode. Press it again and it will go into the ON mode with the engine off.
Originally Posted by Maintenance Manual:
Reset the maintenance data (U.S.A. only)
After the required maintenance is performed according to the maintenance schedule, please reset the maintenance data.
1. Display the trip meter “A” (→P. 249), then turn the “ENGINE START STOP” switch off.
2. While pressing the “ODO/TRIP” button, turn the “ENGINE START STOP” switch to IGNITION ON mode.
3. Keep the “ODO/TRIP” button pressed for about 5 seconds. The resetting procedure is complete when "000000” in the trip meter flashes once and the message in the multi-information display disappears.
I had my RX in for the 20,000 service last week (basically just change the synthetic oil, rotate tires and check the fluids). Total cost including tax was $101.95
I've seen prices here as high as $350 for the same service at the Lexus Dealer.
Coffee at Toyota was Starbucks, but no chair massage or shoe shine.
Davenlei
GX - 1st Gen (2003-2009)
10-10-11 03:23 PM
