Who Has the Highest Mileage on their Gen3?
Old 01-30-18, 12:15 AM
  #76
Sandi_k
Sandi_k's Avatar
Originally Posted by Ssd108
Sandi - have you never thought about doing a transmission fluid change? My wife drives 2010 RX350 AWD. Bought it Jul 2015 with 74k and now has about 93k miles. Got both front transmission fluid as well as rear differential fluid changed few weeks ago. My indy mechanic said that the transfer case fluid level and condition was just fine so didn't do it.
I've changed tranny fluid every 50k miles; differential and transfer case fluid at similar intervals.
I actually went over the complete maintenance schedule before deciding on what items to get done. Got the brake fluid flushed too since we didn't know when it was last done. Next item would be to replace the radiator coolant in about a year or so.
Yep - fluid and filter changes have been the majority of the maintenance work I've done on this car.
The rear shocks were leaking when we bought the car so got that done as well as both front and rear brake pads at the time of purchase.
Anything else I should be looking out for?
I haven't had leaking shocks or struts - all original still at 212K miles. The strut on the rear hatch is starting to fail.
Other things I've done: fuel filter; PCV valve replacement; re-torque the drive shaft and axle bolts; replace fob battery; AC and cabin filter (easy and cheaper to DIY); alignment; replace wiper blades; replace the transfer case gear oil; replace all rubber hoses and couplings; replace thermostat and housing seal (the last 3 items at 200k mileage).
Old 01-30-18, 12:20 AM
  #77
Sandi_k
Sandi_k's Avatar
Sandi - you mentioned earlier that you liked the Yoko's better than the Nitto and got 62k miles from them. So did you go with the Nitto's just due to the little extra miles? Were they comparable to the Yoko's in all other parameters? My wife has a 2010 RX350 AWD and will be needing tires sometime next year - so just to trying to put a scratch list together for when the time comes to do more research and pull the trigger.
The Yokos felt a little softer (I have the Sport suspension) and they were a little quieter than the Nittos - but I didn't get 62k from them - I got 62k from the Nittos. So I couldn't bear buying the Yokos when I could get nearly 50% longer usage from the Nittos. So I've bought the Nittos, and plan on 60k miles (or 2.5-3 years) from them.
Old 10-04-18, 03:17 PM
  #78
jer
jer's Avatar
Just FYI- we are just having our 3rd gen/2004 RX in for service getting brakes. 73k miles, basically all city. Can't complain
Old 10-05-18, 09:38 PM
  #79
Sandi_k
Sandi_k's Avatar
Your 2004 is NOT 3rd Gen. The 3rd Gen started with the 2010 model year.
Old 10-06-18, 04:35 PM
  #80
RichS
RichS's Avatar
I just passed 199K miles yesterday. Oil changes every 10K, regular maintenance schedule, 1 battery and 3-4 sets of brakes. A/C stopped working yesterday - this may be the first non-consumable repair I'll need. I'm hoping it's just the relay. But even if it's big $$$ for a compressor, I can't complain after 9 years/200K.
Old 10-06-18, 06:53 PM
  #81
Sandi_k
Sandi_k's Avatar
I hit 230k miles last week.
Replaced the battery last year, did front and rear brakes a few months back. Only other item that's "non standard" was to have the steering column lubed because it groaned and crackled when hot.
Old 10-08-18, 07:39 AM
  #82
JM1
JM1's Avatar
Default Jm1
Well, I had to let go of my RX 450 h (2010) after getting estimate on air conditioning repair and soon to be required maintenance items. Closest dealer too far and we needed a reliable car for long distance. Hated to do this and will follow all of your exploits with envy. I got to 274,000 enjoyable miles. Thanks for the advice along the way.
The following 2 users liked this post by JM1:
RedRover (03-08-19), Sandi_k (03-08-19)
Old 10-10-18, 07:51 AM
  #83
afpj
afpj's Avatar
[QUOTE=Sandi_
Other things I've done: fuel filter; PCV valve replacement; re-torque the drive shaft and axle bolts; replace fob battery; AC and cabin filter (easy and cheaper to DIY); alignment; replace wiper blades; replace the transfer case gear oil; replace all rubber hoses and couplings; replace thermostat and housing seal (the last 3 items at 200k mileage).[/QUOTE]
Where is the fuel filter? I have not seen this mentioned very often. At a measly 114k miles, will have to be doing the spark plugs soon. thanks
Old 12-09-18, 12:42 PM
  #84
cshimojo
cshimojo's Avatar
Hello!!
My 2009 ES350 had rear ended and total last week.
With money from insurance I have purchased 20011 RX350 with 155,000 miles from Lexus dealer.
Just about 7 years and 155K.
This cars looks unbelievably like new.
I am expecting to use another 150K.
Old 03-08-19, 10:39 AM
  #85
Sandi_k
Sandi_k's Avatar
And it's in the shop today for the 240k service.
Oil & filter, differential fluid change, coolant flush, spark plugs, re-torque drive shaft and axle bolts.
Probably time to replace the struts and shocks, but DH will do that for me.
Old 03-08-19, 02:29 PM
  #86
coachz
coachz's Avatar
240k! Thats awesome. DD Yaris is at 216k with zero issues. Our 2010 RX has 49k.
Old 03-09-19, 01:36 PM
  #87
Athaml88
Athaml88's Avatar
Default 510000 in mine
I have 500k in mine ,GCC version, everyday drive 250km average....
it can run another 50000km
Extreme care was given to engine , 4500km oil change and no sudden acceleration, never off road, never stressed engine ,
thanks
Old 10-06-19, 05:50 PM
  #88
Sandi_k
Sandi_k's Avatar
OK, so this is now Year 9, Month 10 of ownership for the RX 350. And it is now time to sell it and move on to the next car adventure.
My last repair/maintenance item was Friday - replaced a TPMS sensor on the rear passenger tire so that the dash light would go away - in preparation for a possible trade-in discussion with the Toyota dealer.
So it's official - I have bought a 2019 Toyota RAV4 Hybrid, AWD, and will be selling the RX. The dealer lowballed the trade-in at ~ 53% of clean "owner sale price."
So I will be ending this journey, having put 256,500 miles on the car. I will sell it myself; even with the averaged "clean FSBO" value of the Edmunds, Kelley and NADA reports at $8,500, the dealer didn't make a decent offer. I would have been willing to let it go for $7k (retail is $10k). They offered $4500, so I said nope.
So pics will be taken tomorrow, the CL posting will go live soon, and I will no longer be a ClubLexus owner. I may still check in every now and then, but I wanted to say Thank You to all here - most especially @kitlz .
ukcats (06-26-22)
Old 10-07-19, 01:08 PM
  #89
Sevn86
Sevn86's Avatar
2010 RX350 with just over 221k problem free miles. oil changed every 7500 - 8500 miles. Think i can take it to 300k before its time to let it go.
Old 10-08-19, 05:34 PM
  #90
Chuckd30
Chuckd30's Avatar
2012 RX350 with 216K, mostly all highway. Never any major issues - always changed the oil religiously. I got this car from my Mom and some of the stuff was never tended to, so I changed the plugs recently and changed the transfer and differential fluids. My next task will be changing the coolant (hasn't been done since ~80k) and I will likely change the transmission fluid (never changed! eek). The tranny shifts great and I'm hoping that all the highway miles make it fine to change at this point.
Quick Reply: Who Has the Highest Mileage on their Gen3?
