RX350 Noise: Gear shift and Break release
Really enjoying my first Lexus, but there seem to be some noise issues...
1. When shifting the gear, especially in the morning, from P to R, it is not smooth making some annoying noise. Is this normal?
2. Also, when realeasing the break, there is some sort of a "thump" noise.
Don't think it is a big deal, but just wondering if these are considered normal.
Thanks.
Thanks.
My '12 RX-350 shifts smoothly and quietly even in Winter in the morning. My old Saturn Vue was loud when shifting into reverse. When releasing the emergency brake it should make a slight noise.
Some of the shift noise out of P will depend on the surface the car is parked on.
A park "pawl" or a steel rod is engaged to lock the transmission into place in the "P" position.
Cars parked uphill / downhill / flat will have the weight of the car against that pawl to different degrees.
Engage the parking brake before putting the selector into "P". This will take movement away & the pawl will have very little weight against it.
A steel cable , a series of springs & a ratchet assembly make up the parking brake. It is essentially a small drum brake assembly, mounted on the inside of the rear brake disc. Look & compare the front disc to the rear. You can see them through the wheel spokes.
Next time you get the car in for service ask them to lube the cables & possibly pull the rear discs. Dirt, brake dust & other debris can get in there & impede the mechanism.
Steve, great explanation.
flashes23
05-20-17 01:40 AM
rajbertel
07-21-15 09:28 AM
