2010 Lexus RX350 front bumper removal instruction...
So I brought my car to a Lexus dealer to have my headlight adjusted. Came home and passenger's side low beam is out. I opened up the casing and found the ignited melted. Called Lexus and they said because my bulb was aftermarket, they were not going to fix it. So now I have to manually replace the ballast. I searched everywhere for instructions on replacing the ballast and only found instructions to replace the headlight and no instructions as to how to remove the front bumper. Does anyone have any experience or diagram that they can share as how to remove the front bumper? Thanks in advance guys.
UnoRedskin (01-08-20)
The pursuit of F
Between the DIY I did for the back bumper and the parts list shown here (note the screws), you should be able to do it.
Good luck!
DIY Rear: https://www.clublexus.com/forums/rx-...r-removal.html
Parts: http://lexus.sewellparts.com/images/...000/522134.jpg
Good luck!
Good luck!
Good luck!
vncasanova
07-15-13 05:08 PM
americk22
SC- 1st Gen (1992-2000)
07-15-10 07:25 PM
