2010 RX350 interior lights went out
I was changing the interior lights for my wife's RX350 and suddenly all the lights went out on me at the same time. Did the fuse in the box went out on me? Any suggestions? Thanks
Ps. I just did the same for my Isf and everything went well....
Based on your post, I'm assuming you left all the lights on while you were working on the car. In that case, one of two things could have happened:
1) you caused a short when you changed the light, causing the fuse to blow and cut off power to all the lights. Find the fuse, replace it and all will be good again - but be sure to check the cause of the short otherwise it'll just happen again and you'll end up buying more fuses.
2) your car went into battery-saver mode that automatically cut power to accessories after 30 min from time of engine shutdown. Just turn them back on and keep going at it.
