Firmware and Nav version?
I have a 2013 RX 450h and curious what other [newer] owners have in terms of the latest firmware/Nav versions.
I was told by Lexus Tech that the SMS issue I have would be fixed by an update to the Nav system yet the dealer told me I have the latest firmware (yet I still have the issue). I do not see a "firmware" version listed and curious what others have.
Model: 11LHENNA-AZ01
Nav: V6613850 --
Blue Tooth 21.210 --
Map Update --- --
Try Setup / General / Software Update
Thx
Nav: V6613850 --
Map Update --- --
Thx
Thanks but I do not see a reference to the numbers I got from my system. The site refers to Gen 2 & 3, and Nav 13.1 and I see no map update listed on mine nor how to decifer the numbers I have listed.
Await to hear back from dealer....
We have a 2014 RX350 and we both have GS3 phones. I just upgraded the firmware on both phones to Android 4.3 and messaging now works. I had to delete the pairing in both the car and the phone and restart both more than once. My wife just left on a trip but I was able to see a test text come through on the Nav screen. I did not get the Nav version, sorry.
I believe you may need the Toyota/Lexus computer setup and software to read the information regarding version numbers of the firmware and that it is not available for viewing on any NAV display.
Have you worked with the Lexus Technology Specialist at your dealership in regards to diagnosing and reproducing your problem? They may have more to say on the matter as their job is to work with the connectivity of third-party products with the Lexus navigation/entertainment system(s). Perhaps they can try to reproduce the problem with a similar vehicle on the lot.
I have the Samsung S3 (Android 4.3) and it has always randomly (mostly never) showed the incoming text message and sometimes does not show the Reply button.
I talked to Lexus headquarters who told me I needed (by my VIN) the update to the Nav to fix this.
(I was not sure what it had to do with the Nav.)
Dealer at 5K checkup said there was a "notice" about this issue (i.e., the lack of incoming text display) but that I had the latest firmware on the car. I was just curious how to find out (if I could).
I left voicemail with my service manager as the problem persists and emailed back to Lexus Tech direct but no word yet.
Thx
Thx
Thx
Thx
When they are referring to the need to update the NAV they are really referring to the navigation/infotainment system as a whole. Much like a computer it has hardware, software and firmware -- software imbedded into the hardware. The latter can be updated though usually done much less frequent than any software update like the maps data points and software. Consider this like the BIOS in your home or work computer.
There are many reasons for being told no update was available. Here are just a few. First would be outright sloppiness. Service Manager knows better than the customer so does not bother to even check though claims to have done so. Another reason would be failure by the shop to update their own equipment and software which might indicate an update was available. The final being that there is truly no update available for you at this time. There may have been one between the time your RX was built and now which was already applied either before purchase or during a previous service.
Finally, be sure to note your experiences regarding all of this on any surveys you are asked to complete and/or by contacting Lexus Customer Service as you have done previous. And be sure to come back here to CL to let us know how things progress.
I just had the firmware updated on mine. I will check what version they have listed in the notes. The SA was absolutely clueless what firmware is. I'm also getting maps updated in a couple of weeks.
Thanks. Odd I do not see a separate line for Firmware so assume it may be part of the Nav. But my versions do not map to what the Lexus Nav (site to buy new map updates) indicate either.
Nav: V6613850 --
Map Update --- --
Nav: V6613850 --
Map Update --- --
I tried that but on the last step on the SERVICE MENU screen, when pressed, it then shows me options for SYSTEM CHECK, HDD CHECK &Diagnosis Recorder. None of these seem to offer any firmware version numbers.
Thx
Thx
I don't know if this works on a 2013 or not. Here's an old discussion.
https://www.clublexus.com/forums/5731588-post17.html
Follow the instructions exactly
Thanks for checking.
