What fuel grade is everyone using on their 2012-2015 RX?
#106
Amazing investigation. Over a 9% difference in HP and almost a 9% difference in torque. The price difference between the two grades of gas is less than 5% here in CA. So I wonder if it is more economical (because of increased mileage) to use premium? Seems like a reasonable conclusion.
Thanks Dinh.
#107
These cars are rate 275/257 are Engine horse power but do to drivetrain loss buy the time the power hit the pavement its reduce by 15%-25%.
#108
Now I wonder if you used mid-grade at 89 octane if you would pick up most of the difference in horsepower? That brings up an annoying question: Why is mid-grade only 89 instead of 90?!!!
#111
#112
So a 15 HP loss at the wheels means you will lose around 20 HP of the engine rating at maximum engine loading. Since this system is tuned for the rated HP with 91 octane, the 93 won't provide much benefit except for very hard driving at high engine temperatures like what you would see on a track or on a dyno test like this. For normal street use, the 87 is going to satisfy >90% of drivers. 87 is cheap and does not knock under normal use, but if you are going to run a track event or pull a trailer at 80 mph in 125F dessert temperatures, you definitielly want the 91 octane (or 93 if you can get it).
#113
The stations in the Chicago area have 87, 89, and 93 octanes.
#114
So apparently when mixed they lose some octane; all the more reason to stick to Premium; in California we have 87, 89 & 91, but are on "summer gas" now from cracking plants plus some
stations are partly ethanol!!
#115
In Chicago they use ethanol at most stations. I think that's how they get to 93.
#116
This is purely anecdotal, and probably of no use to anyone... but I used to own a 2006 RX400h and only put regular gas in it for the 3+ years I drove it. I averaged about 23-24 mpg (combined). I now own a 2010 RX450h and have been going exclusively with premium. My combined average is now 29 mpg... a 5 mpg increase. My driving habits (I'm a fairly aggressive driver; always in a rush) and driving routes have been unchanged with both vehicles. Now I understand that the 450 is more efficient than the 400 but by only 3 mpg (per the EPA). So while I can't chime in with any opinion on increase in torque or hp... I believe premium does increase fuel efficiency by some margin. Maybe not much, but I would say it's definitely a noticeable difference.
Personally, I think it's a complete no-brainer to go with premium here in Hawaii as the difference between 87 and 91 octane is only about 20 cents/gallon (<5% difference).
#117
Based on what you said, when i pick 89, they mix more of 87 than 93. And if i pick 91 then 93 more than 87? How i can i trust that :-p
#118
The station I go to has three tanks marked in the ground they are color coated. We have 3 grades.
#119
#120
Been reading quite a few threads, but nothing seems to be real pinpointing the answer to my question. Recently purchased a 2013 RX 350, and when i bought it i was told that i should use regular fuel, and not to ever mix it up. Then i hear from other people, that i should use premium fuel because later on in the future, its gonna bite me in the
, and damage my fuel sensor. So what really is it? I do not mind either to be honest, whats a few bucks extra for premium gas when i got a 40g+ k. Just want to get it right, Thanks. Oh, and i basically try to find places to go since i got this car.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
