Text messages in 14' rx350
Old 01-15-14, 02:42 PM
  #31
jakepdx
jakepdx's Avatar
I don't have an Android, but it's my understanding that they can do that and even read (and reply, I think) to emails as well.
Old 02-06-14, 09:34 PM
  #32
my1strx350
my1strx350's Avatar
I have the 2013 RX350 with Nav Package. I just read about the siri feature in new RX350, is there any possibility I can update my RX350 software to enable siri ?
Old 02-06-14, 10:55 PM
  #33
RX330inFL
RX330inFL's Avatar
Sorry, no. Only comes with the new 2014 vehicles and it only supports Apple devices.
Old 02-07-14, 08:59 AM
  #34
jakepdx
jakepdx's Avatar
In case you're thinking this should be easy enough to do, it's actually quite complex. For example, the stereo can be completely off (or on the radio, or something) and you can tell Siri to play a song, and the car will switch the radio on, turn it to bluetooth audio, and then start playing the song.
Old 02-07-14, 09:04 AM
  #35
dmccombs
dmccombs's Avatar
Actually, I do think it should be easy to do. From what I understand, the hardware in the 13 and 14 are the same. They have already written the software, since the 2014 is running the necessary software. What else is needed except to update the 2013 firmware with code used in the 2014 firmware?
Old 10-17-14, 09:56 PM
  #36
PeteInGilr
PeteInGilr's Avatar
Originally Posted by dmccombs
On the 2014 with an iPhone 5, you can receive Text messages, and have them read to you. On the iPhone, you have to turn on Notifications to make this happen.
On the 2014, you can also use Siri to read and reply to Texts and Emails.
I'm stumped...recently switched from ATT iPhone 5 to Verizon iPhone 5s and I am no longer able to hear my text messages read aloud to me while driving (and verbally reply).
"Allow Notifications" is turned on in settings on the iPhone.
Any suggestions?
Old 10-18-14, 06:35 AM
  #37
Lexipro
Lexipro's Avatar
On your iphone go to settings/general/ and turn on Siri. Then press and hold the off hook button until you hear the Siri command. Then tell Siri to read the last text message. Simple as that.
Old 10-18-14, 09:16 AM
  #38
PeteInGilr
PeteInGilr's Avatar
I am aware of that option. I'm trying to find out why the incoming message alert is not displaying on my nav screen when I receive the message. Then I have the option to listen to it or ignore it.
Old 10-20-14, 06:52 AM
  #39
Mors
Mors's Avatar
On your phone, have you gone to Settings...bluetooth...the circled i...turn everything on.
Old 10-20-14, 10:02 PM
  #40
KeithPI
KeithPI's Avatar
I had the same issue when I went to the new iPhone 6+. I previously had the message screen come up when I got an incoming text message, but it stopped with the new phone.
Go to Settings, select Bluetooth, then find your car's connection profile under My Devices (mine says CAR MULTIMEDIA.) Tap on the blue circle with the i inside. The first choice listed in the next screen is Show Notifiications. My guess is that it is turned off. Tap the sllider to make it green, and your notifications should start working again.
Apparently, even though I did a restore from my 5s backup, it did not maintain that setting. It took me quite a while to figure that out! Hope this helps.
Keith
John828
01-06-20 05:45 PM
RLM
RX - 4th Gen (2016-2022)
02-06-18 05:59 PM
Stereorob
02-15-16 09:16 AM
cripsy
NX - 1st Gen (2015-2021)
10-12-15 07:14 AM
Notts
RX - 3rd Gen (2010-2015)
01-07-14 06:39 PM
Quick Reply: Text messages in 14' rx350
