Rattle Rear - Appears to be suspension - Video
This bad squeaking, loose rattling and (sometimes) banging noise from the left rear started happening about a couple weeks ago. I've removed all interior panels, even the exterior bumper thinking there was something loose and nothing. I suspect as a last resort it has to be the suspension despite the car having only 17k km.
What is strange is the rattle increases in sound volume and occurs more often the longer you drive and also if temperatures get colder.
In other words, if I have the car parked in my garage overnight (slightly above 0 C) and immediately drive next morning into sub-freezing temps and on bumpy roads, you don't hear it. But after 5-10 minutes of driving, you start to hear it and gets louder and more frequent.
Searched other threads and some have reported the shock as the problem for 2010/2011 models, but none had any sound or video to compare.
What do you guys think? The video shows how bad it is.
Thanks for the suggestion. This is an interesting one...
http://youtu.be/F_R9nT-yYFY
have you checked the spare tire? if you think shocks are the problem, just drive VERY slowly over a bump and you will hear a thump. but from the sound of your video, I suspect it's a loose spare tire.
On smooth roads, no rattle or noises. On rough roads, it's not consistent. Then temp seems to also play a factor. I'll have to try and pay close attention to a speed bump...
Found Root Cause - Rear Hatch!!!
With my wife driving and myself in the trunk, I found the rattle noise coming from the rear door since the moment I pushed against it, rattle stopped.
It's amazing how fooled I was into thinking the sound eminated from the wheel well!
I put some 3M hockey tape on the rear latch and knock on wood the rattle did not appear in my test drive afterwards.
