"Carplay" just around the corner
#76
Eric told me that the engineer was working on another firmware update after the one they just put out this afternoon(yes it was quick), but not certain what he was focusing on.
When you updated , did you disconnnect the cables to the video interface? Specifically the main wiring harness, that removes power to the unit?
--Mike
--Mike
I took off the Black panel that is underneath the passenger side airbag/glove compartment, tight behind the glove compartment is where my video interface box is. I pulled this downward [more like wiggled it gently but firmly], it doesn't fall down due to how tightly it is held behind the glove box. Once the entire box was exposed I disconnected all of the cables. The in/out cables, HDMI, and the power harness. Then I ran it back up to my room to plug the unit into my computer and update, ran back down plugged it all back in and pushed it back into where I had pulled it from.
I think it's important to note it did not go back in where I pulled it from, but it's not hanging loose or in a concerning manner and is completely concealed again by the black panel. Once we get a fully functioning update... Or rather the "final" update, I will take the passenger side area apart again to button it all up. But for now the quick easy access to the unit is my preference since we are updating so regularly.
#77
--Mike
--Mike
Just installed the newest update. I am cautiously optimistic. Everything appears to be working perfectly.
-Backup Camera functioning
-Factory menu is useable
-Menu instantly activates Siri
-Buttons to change music instantly changes music
The screen turned on two times in a row this morning, however as you know... This doesn't mean it's fixed. I am hopeful but this will need testing of course.
#78
Morning!
I flashed the update as well. Same for me except My Menu/Siri button works as expected,but only when in ACC. When the car is running, it doesn’t work at all. Still getting the white line / flashing screen for a number of minutes after startup.
#79
My menu/siri works completely when the vehicle is turned on [I have not tested ACC]. The display looks great! I will have a flash of white line however, that is only right as I turn the vehicle on. Carplay and the factory menus seem to render perfectly with no graphical errors or flashing white lines such as what occurs the moment the screen flicks on.
#80
Thats odd. Are you in a 2014 Rx 350 with Nav?
#81
Ah I am in a 2014 Rx350 with Nav.
I wonder if this has created some differences in our software requirements? As it appears up to this point we are now experiencing different issues.
I also wanted to ask, did you purchase the device that you attach to the aux cable to get rid of that high pitched sound when the speakers are turned up? If so has this distorted or removed any bass from your vehicle? I read in multiple reviews that the device distorted lows so I haven't pulled the trigger on this.
#82
BTW, is your's a Japan build or a Canada build?
#83
#84
#86
Send an email to: info@beatsonicusa.com and ask Eric.
#87
I don't know for certain, but my impression is that 2013 and up RX are the only ones supported.
I have been meaning to update you. I am on a trip right now so I haven't had the time.
Carplay since the last update I took from Eric [the one previously discussed], has been *almost* flawless! In fact it reliable turns on 90%+ of the time. It has been super super nice for the trip I am on.
I excitedly reported to Eric on this, and he came back said they were working on another update as it needs to be perfect. I am pleased to hear this, and it seems we are close!
How is it on your end!
#88
Hey!
Eric sent me two firmware updates, I think, since you flashed your last update. The first one was a step backwards, the most recent is a definite improvement for me. I get a reliable start of the system > 95% of the time, but that’s a small sample size, maybe 20 starts. My RX is not my daily driver.
The only thing left to correct is the flickering screen (see my video attachment a few posts back) which always goes away after a few minutes.
If their support and responsiveness wasn’t as great as it has been, I might have considered other options. I feel they are determined to get it right.
#89
I would rate it 9/10 at this point. They lose 1/2 point because of the flickering screen and 1/2 point for the occasional blank screen on startup. I am **** about not starting the car unnecessarily.
I also do not wish to nor do I enjoy starting my vehicle over and over. Hopefully Eric has a firmware update this coming week that tightens everything together. It's a shame your screen is still flickering, I just need the screen to reliably be at 100% instead of 90% ish. Out of maybe 25 vehicle starts it hasn't turned on maybe 3ish times.
#90
Ah I was angry for maybe 2 weeks solid in the peak of the issues. Once I discovered I didn't have to take the dash apart to update the thing [I will have to to reinstall it correctly but I am waiting until this is perfect], I simmered down a bit. Now that it is working most of the time I am happy with where it is but I 1000% expect it to reach perfection soon.
