Suggestion for parking very close inside garage
As you can see from the attached photograph, there is very little room in my garage to park two cars. They have to be precision parked.
Has anyone installed/used a laser guided parking device such as ? What are your experiences? I am open to alternate suggestions.
My garage is 20' x 20', not large. But there is space between the edge of the garage door and edge of wall so I 'pull' the Lexus in giving room to open the drivers door. I 'back' the Vette in also giving room to open that 'long' drivers door. Maximizing the available use of space that way.
Has anyone installed/used a laser guided parking device such as this one? What are your experiences? I am open to alternate suggestions.
Then again thats considering you don't have kids or someone else who will swing open the doors either way
If your concerned about getting as close as possible without hitting anything I just tied a little stuffed animal onto the top of the roof and dropped it down.
My garage is 20 x 20 too, and we have the rx350 and a Honda cr-v. Since my RX350 has the parking assist option, I find it very helpful when I pull in the garage. Also, I manually fold down the side mirrors before entering the garage.
Wow, that is very tight! One other option is to suspense couple tennis ***** from the ceiling and use them to guide you in.
What size is your garage? I thought the minimum standard garage is 20x20. Anyhow, I do what others have suggested. One pulls in while the other back in to maximize space for both drivers' sides.
Maybe a garage reorganizing is in order. That's an accident waiting to happen.
I would recommend placing a concave mirror in the middle of the wall to give you some visibility relative to the other vehicle.
Wow that's tight! LOL, I thought Cflutist started this thread! We have tight parking also with two cars but I've got the distances down now with some experience. I also pull in the mirrors each time and edge as close to the side of the garage also. I do use a technique of coming in att a slight angle, then straightening inside the garage. We don't use side ***** hanging down (which is an interesting idea) but I did put a 4x6 wood beam on the floor to know when to stop.
Pulling out, we just have to be very sure to pull straight out.
Most of the time I pull in with about 6 inches of clearance from the right side of the RX450h to the garahe door. Been doing it that way for 16 years (and various cars) and haven't hit the garage yet.
The pursuit of F
Sweet Stingray Jim!
I would just expand the garage ... maybe just go for a three car garage. It would probably be easy to do. I built a three car garage at one of my vacation homes and it was pretty cheap. Garages are typically not complex structures.
Where we lived if you expand the garage, you'd need a building permit. You get those on the condition that the whole house needs to be upgraded - ALL faucets, showerheads, toilets, etc need to be low-flow, CO detectors in every room, etc. That cost adds up!
Fortunately, our garage is big enough for our two cars. I find the Intuitive Parking Assist feature on the RX absolutely perfect for telling me how far to pull in. I pull in until it beeps and car position is perfect. Now, side to side is a different story. I pull in at an angle and then straighten out, much like parking in a parking lot. That way I'm sure the mirror has cleared the bricks at the side and there is room to open the door without hitting the Forester. Walking by on the right is a bit snug, but not bad.
I do back out watching the right side mirror very carefully. I prefer to clear the brick by at least six inches. When it looks like it won't clear by more than an inch or so, I can always pull forward and back out at more of an angle.
But I do end up with wavy tire tracks on the floor instead of straight lines!
