Complete DIY - Eliminate B-Pillar Ticking and Door Squeaks
The pursuit of F
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
After hours of troubleshooting and dismantling, found how to resolve the infamous B-pillar ticking. In addition, resolved the majority of those pesky minor door squeaks.
After the fixes implemented, door slam sounds even a little tighter and car rides quieter too. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Before continuing reading, I must state the disclaimer that neither I nor CL is responsible for any negative impacts to your car as a result of this. With this out of the way, here is a culmination of tens of hours of troubleshooting, dismantling, and with the help from other posts!![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
1. This B-Pillar DIY thread is still valid and should be done as this is one source of ticking: https://www.clublexus.com/forums/rx-...-b-pillar.html
2. This front door trim fix should also be done: https://www.clublexus.com/forums/rx-...esolution.html
3. This grab bar is another source of squeaking: https://www.clublexus.com/forums/8080051-post37.html
4. The rubber stopper is another source: https://www.clublexus.com/forums/7919645-post10.html
5. The door latch tightening by Lexus is not a DIY (or at least not for me at this time) and I want to mention that I have NOT had Lexus perform this fix since I have not had the need to (yet)
but some of you have reported this works.
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Denzo (05-26-17)
The pursuit of F
To confirm this is what you hear, I recorded the annoying sound which happens sporadically on both smooth and rough surfaces and from cold to warm temperatures.
After hours of troubleshooting, my conclusion on the source of the ticking is a weld/glue not perfectly done and thus is creating the metal ticking noise. Which weld, not sure but I suspect it's the top one in the B-pillar. It then reverberates in the hollow B-pillar's chamber creating the sound we hear. However, the fix works and it's to completely muffle the sound thanks to rubber asphalt coating and foam insulation applied inside the B-pillar cavity.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
See pics for the rest!
The pursuit of F
Remove door panel video:
And from fellow CL member:
https://www.clublexus.com/forums/rx-...he-scenes.html
One important tip not mentioned is that in order to remove the door panel as a final step after all four screws and clips are popped out, the panel is still tied at the top. You must PULL it UPWARDS (and not towards you) with some moderate force.
Another find was that the screws were not tight. You should check all screws for a tight fit, but do not overtighten.
Another find was that one of the plastic welds was undone. I apply a flame over it to melt and fuse it back.
Final tip is you will need to bang against the panel when placing it back on to ensure the clips snap back in the holes.
See pics!
See pics!
The pursuit of F
Similar to the Front door DIY step above with the exception of having one less screw, and as such, I am not showing the rear door panel. I do show how to remove the window trim, done after pulling away the door panel. Removing the trim is a little tricky since you need to get at the gray plastic screw underneath the door panel and you must pull the trim away towards you.
See pics!
See pics!
alisher (01-04-17)
Is it weird that my car has no rattles or squeaks and every noise i can hear is due to other things in the car, the most annoying of which being my kids baby seat which has a rattling belt!!
The pursuit of F
^^^ Rayaans. Anita has been pretty quiet about her car's state of noises so maybe she has none. I'd like to know. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
If she and other h owners don't, it would appear "Made in Japan" for the 450h's makes all the difference here. Small things like glue that would be locally supplied used in the assembly may make all the difference between the Canadian 350s and the Japanese h's.
Excellent write up. Can I request a DIY for fixing the right rear seat rattling from the seat adjustment bar? =D
The pursuit of F
No, I don't play soccer!
Yep, the 450h is still quiet after 4+ years. But I tend to keep the stereo volume high, LOL! Some people might be more sensitive to squeaks and rattles than others. Understand I don't say that to diminish the problem. If I had a pesky noise coming during a long road trip, I'd be ripping apart panels too. But fortunately I haven't had any to date.
Thanks for your yeoman's work regarding the " tapping noise " issue. Is this post a different solution to your original fix which involved the tape backing behind the felt? Thanks again.
The pursuit of F
Another tip which I don't believe I mentioned is putting a thin layer of Vaseline (petroleum jelly) on the surface of the door rubber seals as I find it also makes occasional tapping noises (result of slight door motions and the dry rubber moving on the car's metal frame). Of course, I never got my door latch tightened by the dealer which may have helped reduce the door motions and hence the tapping.
Thanks. The darn tapping noise directly adjacent to my ear is driving me nuts. Still can't figure out if it is coming from between the window and the stripping or somewhere from the B-pillar.
