burning smell in cabin
Old 09-08-14, 08:24 PM
m1964
m1964's Avatar
Default burning smell in cabin
When starting the RX, I smell something I would describe as "burning insulation".
It happens only first 10-20 seconds after the air comes out from the vents, and then the smell disappears. The smell is stronger after prolonged parking- it is the strongest in the morning and less noticeable after I start the RX 2-3 more times ( I usually make 6-8 short trips during the day).
The smell was very strong awhen I started the RX first time after it was parked for one week (while we went on vacation).
There are no warning lights, and the vehicle runs just fine.
I pulled out the carbon cabin filter (changed about 3 mo ago) - it did not smell and was very clean still.
any thoughts?
I am hesitant to go to the dealer-afraid they will rip apart the dash, which they probably will not be able to put back together without having rattles and noises after.
The smell comes from the inside- there is no smell under the hood after I start the RX
thanx
Old 09-09-14, 04:05 AM
txes
txes's Avatar
Take the car to the dealer.
You're not going to get your issue resolved posting about it here.
Old 09-09-14, 06:47 AM
raylor4
raylor4's Avatar
Be sure to tell them of your concern about ripping apart the dash.
Old 09-09-14, 07:17 AM
oohpapi44
oohpapi44's Avatar
Guess you're going to have to leave it there parked for them to notice the smell.
The strongest smell after you parked for a week lasted the same 10-20 seconds?
Weird that the more you use it, the less you smell it. Typically its the other way around.
Old 09-09-14, 07:44 AM
vlad_a
vlad_a's Avatar
I would inspect under the hood. Rodents nest can have a similar smell.
Old 09-09-14, 09:51 AM
benzo555
benzo555's Avatar
Check under the car and see if you did not catch a trash bag under the exhaust pipes. Very common problem around my area.
Old 09-09-14, 08:24 PM
m1964
m1964's Avatar
Thanks to every one for your replies. No smell from under the hood. As per shop foreman, it is a common issue with new Lexus vehicles because in hot weather the climate control system goes into recirculation mode. The water in the evaporator box cause mold and mildew build-up. The dealer will clean the evap box through the drain line The issue is documented and is not specific to lexus but the newer ones apparently develop the issue sooner.
David847
RX - 4th Gen (2016-2022)
01-09-17 01:51 AM
Qkimbrell
05-19-16 07:10 AM
rickysan
05-10-16 07:22 AM
LeeJonah
01-15-16 11:49 AM
LEXMICK
RX - 1st Gen (1999-2003)
05-30-05 08:57 PM
Quick Reply: burning smell in cabin
