Please help dash cover removal
Please help me by providing instructions on how to remove the blank rectangular cover on the dashboard below start pushbutton, I think its where the heads up option normally goes? Please see attached picture Thank you
RX450H 2013
Nav package
No heads up
ML stereo
towing
RX450H 2013
Nav package
No heads up
ML stereo
towing
No, I don't play soccer!
The cover is probably held in place by tabs. You can use a screwdriver to release them. I've used a plastic card to minimize damage.
Try slipping a thin plastic card in there to find the tabs. Then push down on them. It's what I used to pop off the interior light covers. I'd recommend starting with the short (vertical) sides. And with removing most parts, the first time is probably going to be the hardest. Good luck.
Everyone thank you for the help. Would you please send me the the diagram? If yes please e mail to Csutton444@aol.com
Thank you again
Thank you again
RXSF Just wanted to say thank you. I followed the instructions and could not have done it with your help! The cover was screwed in from the back side and used as stowage for option connector. See pics thanks again Chuck
