What to look for — 2011 factory warranty expiring
I just bought a CPO 2011 RX 350 (non-nav). It has about 2k left on the factory warranty before the "limited" CPO kicks in. So far it seems mechanically sound. Are there any TSBs or common issues I should bring up to the dealer while still under the original warranty? I have a very minor squeak in the door which is covered now, but not by the CPO.
I was told by Lexus that once they make a vehicle CPO the original factory warranty is no longer in effect. This may be wrong, but you should confirm this with the Lexus dealership you're purchasing this from.
factory warranty will be applied until it is over 4 years/50k, then cpo will kick in. CPO basically will cover any issues except for trim concerns and rattles in most cases.
2011 rx 350 common issues, timing chain cover leak, rear shocks leak, squeak from rear going over bumps or vehicle is swayed side to side caused by rear trailing arms, cds from radio will eject on its own, steering wheel groaning from input shaft,
