2015 RX350 Shift Gear Questions
First time Lexus and RX350 owner. Not familiar with the new type of shift gear. When I shifted the gear from Park to Reverse straight down instead of moving to the right first, the vehicle would jerk and make a thud sound
. Not sure if this would have damaged anything
. After I have get used to moving the gear to the right first before shifting down, I would still sometimes have this jerk/thud. But if I do the whole shift movement (shift the right first) real quick then the chance of getting the jerk/thud is much less.
Any one has the same experience? Is it a manufacture defect or just I am not doing it properly?
Please help.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Please help.
Is this during high idle speed, like on start during cold weather? Any car will shift with a thud if the idle is high. If this is the case, can you give your new car 30 seconds or so to warm up a little before shifting?
Please help.
Please help.
http://image.trucktrend.com/f/multim...erior_view.jpg
unless you have a RX350 that's different from everyone else out there, it is almost impossible for you to shift from P to R without pulling the lever right then down, except maybe if you have a broken shift gate panel.
Hi Dajushi,
My Nx facing the same problem as you. It all start from you shifting from R to P, you need to do it right at this step and shifting out from P to R in later will be smooth.
I manage to overcome this by shifting from R to P properly. Please find my details post on NX forum today.
Hope you get rid of this problem soon.
Flapjack1
04-15-11 08:28 AM
