35k mile service due on 13' leased RX350 - what are my options? (HELP)
35k mile service is due on my leased 13' RX350 - what are my options service wise? I'd like to save money if possible, cringe everytime I get fleeced for an oil change or tire rotation. Is an indy shop a valid option considering it is leased?
Andy
Andy
No, I don't play soccer!
Andy, the 35K is minor service without an oil change. I assume you've had the 30K. That should have included an oil change, tire rotation and other things. You can take it anywhere you like for service. Just save the receipts as proof. Some members go to Toyota since it's less for the same parts..
They will just check some stuff, and fluid levels, rotate the tires, maybe change the engine air filter or cabin air filter, and possibly try to sell you new brake pads and or tires.
Per the federal Magnusson Moss warranty act you can take your vehicle anywhere for service as long as you document that it was performed per the manufacturer's requirements.
