how to remove backdoor/liftgate panel just under center brake light?
Old 03-12-15, 11:41 AM
wxc161
wxc161's Avatar
Default how to remove backdoor/liftgate panel just under center brake light?
First timer here.
Would the plastic panel under below the center brake light pop out with trip removal tool without touching any vertical panels?
Seems like that panel is tightly attached to the back door frame.
I need to run a wire underneath to install a rear dash cam.
Thanks~
Old 03-12-15, 01:38 PM
titomang
titomang's Avatar
You have to remove the L&R side panels but before you do that you have to remove the liftgate panel to access the screws. I had to tap into that center brake light to install my Meteo taillights. I will try and scan the instructions when I get home.
Old 03-12-15, 02:08 PM
wxc161
wxc161's Avatar
Wow, that's more work than initially thought. Thanks in advance for the instructions!
Old 03-13-15, 08:17 AM
mohrd
mohrd's Avatar
And just a word of caution...when you reinstall, make sure the clips are attached to the trim piece and not the metal. They will have a tendency to fall into the lift gate if the other way around.
Old 03-13-15, 09:14 AM
wxc161
wxc161's Avatar
Thanks mohrd for the caution...
Old 03-13-15, 10:01 AM
titomang
titomang's Avatar
Here you go. It's not the best pictures but I hope it helps. And mohrd is correct, you have to make sure that the L&R trim clips are attached to trim itself before re-installing.
leezh (06-20-22)
Old 03-13-15, 10:10 AM
wxc161
wxc161's Avatar
many thanks titomang. greatly appreciated...
Old 04-09-15, 10:23 PM
mailman65
mailman65's Avatar
[QUOTE=titomang;8952057]Here you go. It's not the best pictures but I hope it helps. And mohrd is correct, you have to make sure that the L&R trim clips are attached to trim itself before re-installing.
[/QUOTE
Are there some instruction pages missing?
Old 04-16-15, 10:23 AM
wxc161
wxc161's Avatar
Figured out that you can remove the horizontal plastic trim (top part of tailgate window) by just forcing it out.
There are about 7 clips that are placed.
RiskTaker (09-22-18)
Old 06-20-22, 09:31 PM
leezh
3rd Gear
leezh's Avatar
Do you have a picture of how to remove the back door?
GoodRevs
06-12-10 08:42 PM
Neza
03-08-10 05:00 AM
denkigroov
RX - 3rd Gen (2010-2015)
03-01-10 08:10 PM
Dietz
RX - 1st Gen (1999-2003)
03-02-09 10:24 AM
SGT
01-31-06 06:29 PM
Quick Reply: how to remove backdoor/liftgate panel just under center brake light?
