2011 RX 350 Rear Back Up Sensors Only
Can't find anything in owners manual about the Back Up sensors on my 2011 RX 350. Just bought it used. Not equipped with "navigation" or "intuitive parking assist" but does have a back up camera. There are two sensors located in the center of back bumper. Would like to turn off sensors if possible.
Thanks
Thanks
Welcome to the forum. If you have the Lexus Factory-installed option, you would have 4 sensors on your back bumper. The Lexus version turns off Intuitive Parking Assist via the options accessed on the steering wheel.
Since you have only two sensors, you likely have an aftermarket version of some sort. I don't know how to help with that, except maybe there is some sort of switch installed under the drivers dash area perhaps... Some of my former aftermarket options were installed like that. Good luck!
I have a used 2011 HS250 with dealer installed parking sensors front and back. It has a green button on the lower left dash that lights up and beeps when the car is started and then starts screaming if you do not press it to turn the light off when moving. It does not appear in the Nav menus.
My point is, to check your vehicle service history to see if a dealer installed your park assist. You can check online at the lexus sight where you log in your vin. Or call the dealer. I contacted the installing dealer for mine but they were of no help with operational hints.
GreatRX350
RX - 3rd Gen (2010-2015)
18
06-03-15 07:51 PM
CCJ22
05-27-12 05:54 AM
