Customization option: A/C auto switch operation
Under the vehicle customization screen there is an option for "A/C auto switch operation"... two options Auto (default) or Manual.... WHAT DOES THIS DO?
(Can't find any info online or in the book...)
THANKS!
THANKS!
What year is your RX? Your profile indicates you have a 2007 RX, but you're in the 2010-2015 Gen 3 forum. Menus on a Gen3 are quite different than a Gen2. I just went out and looked at the menus on my 2013 dealing with climate control and I don't have the option you're referencing that I can immediately see... Also, if you do have a Gen2 RX, let us know if you have Nav or not -- IIRC (and I could be wrong), options how to control A/C vary based on that as well.
One of the other Mods or I can move your question over to the Gen2 forum if need be, so hopefully folks with the same model as yours can assist if you're in the wrong place.
For the record, my 2nd gen had a regular button. It didn't have the always-on auto feature like the 3rd gen. I realize that might change with option packages, but I am pretty sure my 2nd gen didn't have that option in the menu. FWIW
One of the other Mods or I can move your question over to the Gen2 forum if need be, so hopefully folks with the same model as yours can assist if you're in the wrong place.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Here's where the option is:
Setup --> Vehicle --> Vehicle Customization --> Climate Settings
I figured it out though after playing with it!! If you have it ON (default) then the AC will come on when you press Auto. But if you turn it OFF, under customization, then the AC will NOT come on when you press Auto. You'll need to manually select AC under the climate screen. This is perfect for winter or dry climates when outside air is just fine.
Darn... I was hoping you'd found a way to turn the AC on and off with a button on the dash. Now that summer is here and I'm using the AC, I realize how annoying it is to go through the Nav screen to switch on or off the AC. I can't imagine what the designers were thinking when choosing not to put a button the the dash. It could be considered a safety hazard as it distracts your attention to accomplish a simple operation.
https://www.clublexus.com/forums/rx-...-c-button.html
Enjoy
novaman
I just leave mine in AUTO all of the time and don't worry about it. My IS has the A/C button and I don't think I've ever touched it.
No, there's no button on the dash to simply turn the AC on and off. There's a button to put it into thr AUTO mode. To turn the AC on and off you must use the navigation screen, go to menu, climate, then select AC on or off. Crazy eh? I'm not the only one who finds this to be annoying. I might try leaving it in Auto mode as others have suggested.
novaman
Do you have the navigation system on your RX?
Actually I was mistaken about having separate AC button. I do not have a separate AC button. Beside the Auto climate button it's an off button. I guess when I made post # 12 I was thinking of my Lincoln LS as it has a separate AC button as well as an Auto button. Sorry for the confusion. Nevertheless, yes I have navigation.
novaman
novaman
novaman
novaman
A separate OFF button. My '01 RX and '06 ES had one, what happened with our '10-12's?
