Shocks Leak
same thing on my 2010, started leaking around 40k miles and apparently its a very common issue with RX family. My are leaking very little so i have yet to replace them, no discomfort or anything during the ride, whether its a bumpy road or high speed maneuvering through traffic.
https://www.clublexus.com/forums/rx-...ocks-leak.html
Originally Posted by pasica
How can the rear shocks on a 2011 RX350, with 38K be leaking? Is this Lexus quality?
Should I buy OEM shocks, since they are so bad, or go for an after market brand? any suggestions?
Thank you
Thank you
They do put certain conditions in their contract, such as x number of failures per set number of units.
So, if their supplier does not deliver, they will switch to the one that will. In order to stay competitive, they also put a cost reduction in place with each iteration. That may end up being counter-productive.
Considering this is a $35 part, this might explain it.
Good news, these are actual shocks, not struts, so no messing with spring compressors and strut disassembly.
The condition itself is not critical and can be taken care of at any time. The car will simply ride bouncier in the back.
I did notice there being 2 sets of part numbers. So, the newer version might have resolved this problem.
Looks like KYB has a set of shocks available:
http://www.tirerack.com/suspension/s...utoModClar=AWD
However, they may be the OEM suppler to begin with. And I believe Toyota does requests their suppliers to provide non-EOM shocks with 10% more stiffness.
Monroe also makes replacement shocks and struts for the RX under their OE Spectrum line. I think Monroe and KYB may be the only 2 brand name suppliers. I do think KYB is the OEM supplier. I did see some no name really cheap replacement shocks & struts on eBay, but would not put them on my car.
The Monroe struts look like they may be a good alternative if they last as they have had good reviews on some BMW forums. http://www.monroe.com/en-US/products/OESpectrum/Struts
TWIN TECHNOLOGY™ TUNED FOR EXCEPTIONAL CONTROL
The Monroe® OESpectrum® struts feature our latest, global, original equipment valving technologies for domestic and foreign nameplate applications. Monroe OESpectrum units provide an unprecedented level of handling precision and control while filtering out ride harshness. This unique blend of control and comfort is made possible through Tenneco’s Twin Technology™ Active Control System, an exclusive internal damping control technology.
Tenneco’s Twin Technology™ consists of the latest Impact Control Valve (ICV), delivers exceptional control by regulating the flow of fluid which helps control vehicle roll and isolate road impact, and a patented Low Speed Tunability (LST) piston design that isolates impact-related noise, vibration, and harshness experienced with rough, bumpy road conditions. Our best ride ever,
Shock leak picture
Assuming you all are talking about this? Just bought this used last week and I see this already; 40K miles on it Not expensive to get it fixed? Will the fluid stain the driveway?
That photo does not look like the rear shock for an RX350. Maybe if it was the European model with air suspension. What make-model vehicle did you buy?
Here is a link of a typical rear shock that is leaking. https://www.clublexus.com/forums/rx-...ement-diy.html scroll down for the rear shocks pics
I would get professional help, if you just bought it, take it back and make them fix it as they obviously sold it to you defective and should have caught and fixed it before sale. Replace both rear shocks.
You can clean your driveway up with any of the many oil removing driveway cleaner chemicals available at any auto parts store.
KYB vs OEM
Lexus doesn't build them per se. They get parts from OEM suppliers built to their specifications.
They cost more than the Lexus shocks and my guess is that they are stiffer than the original.
I can't really say that with facts to back it up though.
If I could do it again I would just get the Lexus brand shocks.
What i was told is that this is common faulty thing with RX and i had it done on my previous RX even without the warranty it was replaced at the dealer for free since it is something that is wrong on Lexus' end
