Unlock button, windows down but not sunroof? How?
Hi just got a 2015 RX, loving it so far, I have been able to fiddle around with some settings to get it the way I want like keyless unlock drivers side door to unlock all doors, keeping iPod screen on with auto changing to maps, and track up on Navi.
However I cannot figure out how to get windows to go down but not sunroof when I hold the unlock button? Is there a way?
I think that setting has to be done by the dealer, and they provide one free time to make those changes on a new car.
Otherwise I think you can do it if you buy the Carista (sp) app and the thing that connects to your diagnostic port under the dash to do it yourself.
No, I don't play soccer!
According to the 2015 RX Lexus Personalized Settings (LPS) the widows and moonroof can be programmed to open when holding the unlock button (or inserting key into driver side door and turning right) or turned off. And it is something only the dealer can program. In the US it's usually done during the first scheduled maintenance at no cost. A good reason to read through the whole list. Or check with Carista to see if their app will allow you to program yourself. I see the moonroof can be programmed to either slide open or tilt when the windows are opened. BTW, turning the key to the left in the driver side door will close the windows and moonroof, and lock the RX.
I just checked the settings with the Carista app yesterday on our 2014 RX350. One of the things I really like about the app is that you can see all the settings and email them to you without paying anything:
The following settings were available specifically to your vehicle using Carista:
Doors / Windows / Remote:
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking/unlocking with remote
*YES* / NO
Volume of beep when locking/unocking with remote
OFF / 1 / 2 / 3 / 4 / 5 / 6 / *MAX*
Beep when opening/closing windows with remote
*YES* / NO
Warn when door can't be locked with remote because it's open
*YES* / NO
Panic function on remote
*ENABLED* / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / *60 SECONDS* / 120 SECONDS
Unlock doors via remote
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Unlock doors via physical key
Unlock doors via smart key (door handle button)
Auto-lock doors when moving
*ON* / OFF
Lock doors when shifting into gear
*ON* / OFF
Unlock doors when shifting into park (P)
ON / *OFF*
Unlock all doors when driver's door is opened
ON / *OFF*
After locking with smart key, allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
Smart key location to start car
FRONT SEATS / *ANYWHERE IN VEHICLE*
Open trunk via smart access button
DISABLED / DOUBLE CLICK / *LONG PRESS*
Open windows and sunroof by holding key in door lock
*ON* / OFF
Close windows and sunroof by holding key in door lock
*ON* / OFF
Open windows and sunroof via long-press on remote
*ON* / OFF
Open/close power rear hatch via interior switch (click type)
SINGLE CLICK / *LONG PRESS*
Beep when opening/closing power rear hatch
YES / *NO*
Unlock via One motion
*REAR HATCH ONLY* / ALL DOORS
Open rear hatch via One motion remote
DISABLED / SINGLE CLICK / DOUBLE CLICK / LONG PRESS / DOUBLE CLICK ON UNLOCK BUTTON / *LONG PRESS ON UNLOCK BUTTON*
Rear hatch open assistance
Instruments / Display / Dings:
Ding when headlights are left on
*YES* / NO
Seat belt warning ding (driver)
Seat belt warning ding (front passenger)
Remote low battery warning
*ON* / OFF
Front parking sensor range
NARROW / *WIDE*
Rear parking sensor range
NARROW / *WIDE*
Mute parking sensor when stationary for more than 3 sec.
*YES* / NO
Parking sensor beep volume
1 / 2 / *3* / 4 / MAX
Activate parking sensors in neutral (N)
YES / *NO*
Enable front parking sensors when in reverse (R)
FRONT / *FRONT CORNER* / OFF
Enable rear parking sensors when in neutral or forward gear
REAR / REAR CORNER / *OFF*
Dash display mode
*ALL* / UNDISP
ECO Drive indicator zone
*ON* / OFF
Lights:
Daytime running lights
*ON* / OFF
Coming-home lights duration
OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / NORMAL / LIGHTER / *LIGHTEST*
Turn on marker lights when vehicle is unlocked via remote
*ON* / OFF
Instrument lights dimming sensitivity
DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / *15 SECONDS* / 30 SECONDS
Turn on interior lights when you shut off engine
*YES* / NO
Turn on interior lights when you unlock doors
*YES* / NO
Turn on interior lights when smart key in range
*YES* / NO
Center console spotlight (bright when doors open, dim when driving)
*YES* / NO
Turn on exterior footlight (on side mirror) when smart key in range
*YES* / NO
Turn on exterior footlight (on side mirror) when doors unlocked via remote
*YES* / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / *15 SECONDS* / 30 SECONDS
Interior light control
Exterior light control
Heater & A/C:
Temperature dial calibration
-2°C / -1°C / *NORMAL* / +1°C / +2°C
A/C evaporator control
*AUTOMATIC* / MANUAL
A/C ECO mode
Auto-increase blower speed when front defroster is on
*YES* / NO
Auto-turn on A/C when AUTO button pressed (if needed)
*YES* / NO
Deactivate front defroster when AUTO button pressed
*YES* / NO
Other:
Slide driver's seat back for easy exit
OFF / SHORT / *STANDARD*
Obtained with Carista 2.4 beta-10 for Android.
Download app: https://play.google.com/store/apps/d...rizmos.carista
Facebook: https://www.facebook.com/caristaapp
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*ON* / OFF
*ON* / OFF
ON / *OFF*
ON / *OFF*
*ON* / OFF
*ON* / OFF
*ON* / OFF
YES / *NO*
*YES* / NO
*ON* / OFF
NARROW / *WIDE*
NARROW / *WIDE*
*YES* / NO
YES / *NO*
Dash display mode
*ALL* / UNDISP
*ON* / OFF
Lights:
*ON* / OFF
*ON* / OFF
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
Heater & A/C:
A/C ECO mode
*YES* / NO
*YES* / NO
*YES* / NO
Other:
I had this setting changed at a local dealer when my RX was in for service. You can change a few of these at no charge. Everyone else also changes their rear door to auto-open when you press the open button on it.
Carista will be able to do the same set of changes.
Hi what specifically did you get change, for the moonroof to not open but windows open on unlock button long press?
22rear295
01-20-09 05:56 PM
