2010 Sunroof sticks
Has anyone had this happen? now and then when I open the sunroof it sticks and wont open... then I close it and try again and it opens but it makes a pop noise as if something sticking.... happens now and then.
I am thinking some grease or oil somewhere is needed?
thoughts?
Thanks
thoughts?
Thanks
Still under warranty? I had this issue on a 1994 Mazda and had to clean and re-grease the rails etc periodically or it groaned and was slow. However, it may be more than that from your symptoms and the dealer should check it out.
has anyone had this happen? Now and then when i open the sunroof it sticks and wont open... Then i close it and try again and it opens but it makes a pop noise as if something sticking.... Happens now and then.
Thoughts?
Thanks
Thoughts?
Thanks
RichardNJ
ES - 5th Gen (2007-2012)
12-27-09 01:03 PM
