Off DST, how do i reset the clock in my RX?
i got frustrated as well. Assuming you have Nav:
go into Info , adjust clock(top right box) ,click(tap) and then undo dst BUT keep Auto adjust on . Mine stayed . Did not revert back. I read somewhere that auto adjust is for Nav time zones not DST.
just noticed that this was in Gen 3 section. Anyways , i did that car as well but it was much easier than my 400h. SO, again ASSUMING you have Nav:
Left click and go to clock, click
turn DST off and keep auto adjust on
auto-adjust has never worked for daylight savings time
i've manually adjusted DST for nearly a decade w/o issue
have had no computer updates in several years
no longer able to adjust time
if i disable auto-adjust, disable DST, or change time zone
the modifications initially work until i exit the screen & they then revert back
any hey-try-this thoughts ?
thanks
thanks
issue resolved
just for the record I don't like DST. There. I said it. In CA it actually increases energy use cuz the sun stays up until almost 9pm radiating heat at my house..... Oh and I don't want to have to use my headlights on my morning morning drive coming to work in October......
I am having issues adjusting the clock in my RX-350. Since it has the nav system, I was instructed by the general manual to use the nav system instructions. Currently, the time zone is set to "central", daylight savings time setting is "on", and auto is "on". However, nothing changes when daylight savings time changes. So the manual told me to turn the auto setting "off" to be able to make manual changes. When I try to toggle the settings, all I get is an error chime. Can someone please help me figure out what it is doing, and how to change it? Thanks in advance!
You have to toggle the DST setting to adjust for DST (i.e. set it to on when it is DST, set it to off when it is not DST). Auto adjust sets the time but it does not automatically adjust for DST.
I wasn't driving, but the car was running. I'll try it again making sure I have it in accessory mode only and see if that makes a difference.
I'm not at all impressed with these manuals and the complexity of the electronics on this car. The electronics on my husband's Ford truck are much more intuitive than these are. I hope they have improved them since 2010.
SoCalRX
RX - 4th Gen (2016-2022)
01-04-18 09:56 PM
triplecore
01-17-08 05:02 PM
