Replace 2 tires in AWD or buy new pre-shaved tire?
What's the science behind the recommendation/insistence to shave a tire to match - on an open-differential system?
The 19" tire that came on my RXh has a new diameter of 29.2 inches. The tire starts out life with 10/32" of tread - with 8/32" legally usable.
Assuming that when the tire is worn down 8/32", the tire will then be 1/2" less in diameter (8/32" from the top; and 8/32" from the other side - since whe're dealing with diametert and not rolling radius) which means that the tire when legally worn out is then 28.7 inches in diameter.
That then becomes 98.3% of what the tire measured when new.
The 713 Revolutions per Mile when new then becomes 725 Revolutions per Mile.
So, for less than the maximum of just under 2% difference in size the recommendation is to throw away over half of the new tire's tread life?
I'm not convinced that there's enough difference to matter.
Would someone please point out the error in my thinking?
Costco are notorious for pulling this scam with AWD vehicles. Next time tell them that the car goes round corners...... oh, wait, that's what a differential is for! And for the reasons stated in the post above, your imperceptibly different tire sizes puts a lot less stress on the diff than going round a corner!
Good point from NateJG regarding the open differentials in the RX. As noted in my earlier post i've had to shave a tire to match my others in my subaru. I recall when i had my old Audi A6, the manual also mentioned that tire tread thickness has to match. According to some further research it appears the differential types that Audi and Subaru uses is a clutch pack type which can get damaged over time if you don't shave a tire. I've erred on this caution when i picked up my first RX300 and newer RX350.
The open diff type found in the RX's and Highlanders per the other Toyota forums should have no concern to put a new tire.
Good to know this now in the event i have a tire situation in either of my RX's.
Thank you all for the helpful suggestions. Thanks "Clutchless" for the eBay link.
The tire wear is at 7/32" after 25,000 miles. After I filled air, strangely enough there is no leak. So I am driving around while considering these options. No snow or mountains where I live.
So if I do the above calculations of "jfelbab", I seem to have used up 3/8ths of the tread and have about 5/8ths (about 62%) left.
This would mean you had between 50% and 62% tread life remaining if just using math. Yet there is more to this than just math. If you don''t rotate your tires regularly, if you don't check the tire pressure often or you have alignment or suspension issues your tread will wear unevenly shortening that tire life. I use an inexpensive tread depth gage to check the tread depth across the tire and at various spots around the tire to see that the tread is wearing uniformly. I check my tire pressures monthly. I have the tires rotated at every service. Finally I replace tires after 6 years regardless of tread depth. If you look to a used tire to fix your issue, check the tire date code and try to not buy old rubber.
Tire date code: http://www.tirerack.com/tires/tirete...151118160109:s
Wear is measured in the UTQG Treadwear Grade. 7,200 miles (Total Test Mileage) * 440% (UTQG number) = 31,680 miles.
The Treadwear rating is a number based on a vehicle test where tires are compared to a control tire. The rating is based on a percentage in projected wear life. So a tire rated at 400, projected twice as far as a tire rated at 200. Since there are many factors that influence wear, such as vehicle speed, road surface, climate, vehicle alignment, and driving habits, these ratings are merely an indication of the wear characteristics of the tire.
7,200 is the distance of the test track used not the specific mileage one would expect based on a UTOG rating.
"These MICHELIN® tires carry a 55,000 mile limited warranty in addition to the standard materials and workmanship warranty for treadwear or mileage."
UTQG rating is pretty much useless unless you want to compare compound softness to another like purpose tire. However you can generalize a higher UTQG numbered tire should last longer than lower rated UTQG number tire.
I think at 25k mi or 7/32 of depth, you are at approx 50% tire life, so it won't break anything if you replace just one tire.
For AWD applications, more drastic differences may cause problems, but this is exactly one of those where you should not have to replace all 4 tires.
At what point does the UTQG rating * 72 consider the tire to be done? At 2/32 or 0/32?
The UTOG rating says nothing about minimum wear. It is a government regulated test procedure to help consumers get an general idea of tread wear, traction and heat.
http://www.tirerack.com/tires/tirete...151119213904:s
The accepted minimum tread depth is usually quoted at 2/32nds but based on wet driving condition tests, 4/32nds could reduce your highway stopping distance by 100 feet. That could keep you and your family out of an accident and possible injury. If driving in snow, the most widely accepted minimum is 5/32nds.
