cargo dimensions, in inches.
Old 01-01-16, 09:32 AM
zilkah
zilkah's Avatar
Question cargo dimensions, in inches.
I've looked high and low for some cargo dimensions for one of the lexus 350..all I am getting is cubic feet but I'm trying to find out if dog crates will fit in the back.
They're 42 inches wide.
Does anyone have the specs (length/width/height) of the cargo space with the seats down (or seats up)?
Sonnyblu62 (04-28-21)
Old 01-03-16, 06:56 AM
chandlervt
chandlervt's Avatar
Didn't measure it but you can get the width from a cargo liner dimensions. On Amazon, weathertech width is 9 x 55 x 9 inches .. So 55 inches wide. If you line up 42" crates by depth, then you can probably put 2 of them side by side with seats down.
I will give you exact dimensions later on today once I measure them. I can only give you with seats up though.
Old 01-03-16, 09:28 AM
ORRX2010
ORRX2010's Avatar
I did a quick measure on this. The way the roof is slanted causes you to lose a lot of extra space.
Length (true) is 49" from top (back of head rest to end of usable space). At bottom it extends to 73" which is good for long flat items but bad for boxy items. Width is 43" at bottom and 44" midway. Height is 29". So you can fit your dog crate or two but it really depends on their height and length.
For a box your dimension would be 49" x 44" x 29" as your height drops you can avail the extra 24" in the butt.
-dan
Old 02-01-17, 11:32 AM
kristenmc
kristenmc's Avatar
Thanks for posting this. I have a very similar question. Do you know if a love seat would fit in the trunk? I'm less concerned with the length (70 inches), because I'm only driving it a few blocks. However, the depth and width of the loveseat, respectively, are 36 inches and 31 inches.
With a bungee cord, it looks like I could probably fit a 70" x 44" x 29" loveseat with it hanging out the back. Do you think I could fit a 70" x 36" x 31" loveseat?
Thanks so much,
Kristen
Old 02-01-17, 01:52 PM
Clutchless
Clutchless's Avatar
Received 1,160 Likes on 990 Posts
I think with the love seat it may be too tall, but depends on if those measurements include the legs. You may be able to wiggle it in there at an angle and then tie the legs to a seat belt ring or floor anchor. If it is only a few blocks that may work. This is one of those things where you may have to try and fit it in to know.
Old 02-01-17, 03:17 PM
F250
F250's Avatar
You can also probably unscrew the legs (at least on most love seats and sofas) to reduce the love seat's overall height for the moving operation.
Old 04-12-21, 03:51 PM
PoqRX
PoqRX's Avatar
Default Cargo space width between wheel wells for 2010 RX450h
Could someone tell me the width between wheel wells?
Old 04-14-21, 07:27 AM
salimshah
salimshah's Avatar
Received 1,047 Likes on 945 Posts
2011 450H --> 44 1/2"
Note the hatch opening curves and the opening dimension at the bottom (flat) is 41 1/2. You can lift an object and angle the box in.
Salim
Old 04-14-21, 07:35 AM
PoqRX
PoqRX's Avatar
I’m trying to see if two dog crates that was 22.5” wide would fit side by side. Looks like it will be 1/2” too narrow!
Salim
theanalyst
NX - 1st Gen (2015-2021)
04-27-17 06:08 AM
OG Dada
GX - 1st Gen (2003-2009)
05-01-15 12:21 PM
ggebhardt
LX - 3rd Gen (2008-2021)
48
03-31-15 12:07 PM
DIYsquirre
SC- 1st Gen (1992-2000)
05-30-05 01:53 PM
Quick Reply: cargo dimensions, in inches.
