Connected the battery cables wrong and now my gas pedal doesnt work
So the title sums it up. Im trying to check which fuses need to be replaced because of this but Im having a hard time accessing fuse box on drivers side. Please help. This is a 2011 lexus rx 350
Definitely check as many fuses and relays as you can before, but you may still end up getting it towed somewhere.
Good luck.
The car starts when it rolls it even changes gears. Just the gas pedal doesnt respond when I press it. I did some research it seems lexus has some idiot proof nets like letting fuses blow out before damage to car
Look at this site and see if it helps:
http://www.justanswer.com/toyota/6ls...html#re.v/459/
It's for a Toyota, but should be similar in this case.
Cliff notes: Under the hood is a fuse box. Open that and find the fuse labeled ETSC and replace it. This will probably cause your check engine light to come on, but you can go to Autozone and have them clear it.
Disclaimer: This is just what I found from google. I'm not a mechanic. If you do anything to your car, it's not my fault.
Good luck with it!
Good luck with it!
mb12345
03-09-11 07:22 AM
