Serious problems with wiper
Old 01-31-16, 02:51 PM
rayaans
rayaans's Avatar
Default Serious problems with wiper
So my drivers side wiper is leaving 3 distinct lines across the screen. It sort of looks like something is being dragged across the screen in the rain even though the wipers are clean.
Like this (except only 3 lines):
Anyway, I changed the wiper refill on the driver's side regardless but it still does the same thing. Any ideas on what it could be? Its not the refills as they are brand new.
Another thing - I used RainX and the wipers have removed it where the 3 lines are (which is why they are showing up as lines).
The 3 lines are exactly where the clips for the OEM plastic housing is which hold the rubber refill.
Any help appreciated. Thanks!
Old 01-31-16, 04:37 PM
GSteg
GSteg's Avatar
If you have clay bar, try cleaning the glass first.
Old 01-31-16, 05:14 PM
rayaans
rayaans's Avatar
I do have a clay bar yes. Ill try it out but I feel like there's way too much tension in the drivers side wiper arm. It squeaks in light rain whereas the passenger side is dead silent.
Old 01-31-16, 06:01 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
Strange, I use RainX between claying and haven't had that happen. Wipers are cleaned every wash. But once or twice the metal inserts caused problems after replacement. I'd check those to make sure they're secure and also put in the same way they were taken out so it makes even contact with the windshield. Good luck.
Old 02-01-16, 02:49 AM
rayaans
rayaans's Avatar
What do you mean when you say that the metal inserts can cause problems?
I put them in the way they came out and was quite careful making sure they didn't bend excessively or put in the wrong way.
Essentially, there are 4 clips on the wiper blade itself. The lines are being left where the top 3 blades are if the wiper is lifted up but not where the bottom one is.
I can remember it being like this a while back but claying and rain X used to solve the problem for 3 months and it'd come back after. Its very odd.
Old 02-01-16, 03:08 AM
kitlz
kitlz's Avatar
Sometimes the metal inserts slip out of the wiper refill when threading through the clips. It often takes me more than one attempt. And the metal inserts have an arch to them. That's what I meant when I said to put them in the same way.
Only other thing I can say is maybe your wiper arm needs to be adjusted.
Old 02-01-16, 06:32 AM
jfelbab
jfelbab's Avatar
I would polish the glass and re-install the insert as a first step.
A tip on cleaning windshields. About once a year I I use a paint polish, like Meguiar's #204. I use a fiber Cerama Bryte pad if I do this by hand or my DA with a polishing pad. Removing baked on road grime and old RainX coating can be very difficult for normal glass cleaners but this approach takes everything off the glass. I'd caution using a polish on the side window glass as it is factory coated to repel water and this will remove that coating. Your windshield is not coated.
Did you replace the insert with a Lexus refill or an after-market refill? I have had better performance and longer life with OEM inserts.
I agree that it sounds like it your issue may be related to the insert or the arm. If you are not very observant, it is easy to improperly install the insert. I'd try removing it and re-installing it as a first step, paying close attention that the insert is installed evenly between the fingers at every mount point.
You could replace the whole arm as a last resort. I would hate driving without clear vision.
Old 02-01-16, 09:16 AM
rayaans
rayaans's Avatar
Ive checked, compared both sides and can confirm that the metal inserts are in their correct slot. I can also confirm that the arch is how it is meant to be.
The refill was OEM bought from Lexus UK online store. The rubber is fine and soft. The refill has been put in correctly - I should mention that the streaking was EXACTLY the same before the new OEM refill was put in so I would say most likely there is something wrong with the arm.
Now how do I go adjusting this arm then?!
Old 02-01-16, 02:31 PM
Clutchless
Clutchless's Avatar
Received 1,160 Likes on 990 Posts
Get a new metal blade. The whole part that holds the rubber. The Highlander takes the exact same blades, so maybe a Toyota dealer will be less expensive. Trico makes them for Lexus. I forget which model it is, but have some extra blade assemblies at home and will check.
Old 02-01-16, 03:06 PM
kitlz
kitlz's Avatar
I haven't adjusted the wiper arm myself but I believe it's the under the cover in the cowl area. Hopefully you're still under warranty. Have the dealer do it. Or maybe they'll replace the entire arm.
True about getting refills from a Toyota dealer. Price is slightly less. MY matters though. Last time I forgot to bring the part numbers and the driver side and rear wiper were not the correct size. The metal inserts are probably available separately.
Old 02-01-16, 08:42 PM
lex_rx
lex_rx's Avatar
I usually like to lubricate the springs and hinges part with wd40 or white lubricate to ensure that whole unit is flexible and then bend in and out.
Old 02-02-16, 04:01 AM
rayaans
rayaans's Avatar
The actual blade is fine and the inserts are OK too. I think its a tension issue - as in the whole metal arm is putting too much pressure onto the glass.
The RX is not under warranty. Its going to be 4 years in June. I might take a look at the arm to see if its bent and then just use pliers to put it back in line.
If that doesn't work then Ill just keep putting Rain X on (which helps a lot just dies off quicker) and wait till I can find a replacement for the 3RX........
Old 02-02-16, 05:51 AM
Clutchless
Clutchless's Avatar
I have found Rain Clear works better and lasts much longer than RainX. It is a second generation product from the same inventor. He sold the RainX company, then after the non-compete expired, started Glass Science to market his second generation stuff which is much better. He also has a Glass Scrub which is great for cleaning before application.
http://www.detailedimage.com/Glass-S...5-oz-Bonus-S1/
Old 02-02-16, 10:04 AM
kitlz
kitlz's Avatar
I use the Glass Scrub cleaner before applying RainX. Good stuff, but it has to be applied to wet windows with something other than a paper towel and rinsed well.
Sorry you're out of warranty, rayaans. It's worth a shot to contact the dealer anyway. Sometimes they will make a repair or adjustment as a goodwill gesture. At the least, maybe they can give you an idea about what the problem might be so you can fix on your own.
Old 02-05-16, 12:41 PM
vlad_a
vlad_a's Avatar
Get a new blade, not a refill. Bosch Icon are well worth the money:
Amazon.com: Bosch 22A ICON Wiper Blade - 22" (Pack of 1): Automotive Amazon.com: Bosch 22A ICON Wiper Blade - 22" (Pack of 1): Automotive
They're one piece, with no arms to trap snow and ice.
Quick Reply: Serious problems with wiper
