2010 Lexus RX 350 - Dummy dashboard lights
Okay, I'm a bit concerned about what appears to be a lack of a low oil/low oil pressure light on the 2010 Lexus RX 350.
During the process of changing oil, I emptied the oil and turned to Run position on the car -- and did not receive a low oil light.
Any ideas guys?
Is there a way to illuminate all the dummy lights?
The following lights come on.
* On the Tach:
* Driver’s seat belt reminder light
* Malfunction indicator lamp
* Electric power steering system warning light
* Charging system warning light
* SRS warning light
* Eco Driving Indicator Light (RX350)
* Center
* Master warning light
* Brake system warning light
* Speedometer
* Intuitive parking assist indicator
* Far right
* Tire pressure warning light
* Slip indicator
* VSC off indicator
* “ABS” warning light
Any ideas guys?
* On the Tach:
* SRS warning light
* Center
* Speedometer
* Far right
* Slip indicator
* VSC off indicator
msat - My owner's manual says on page 546 that the low oil warning is in the "multi-information display" located between the tach and the speedo. When there is any warning you will also get a "master warning light", yellow triangle. This is in chapter 5-2 of my '11 RX350. There is no "idiot light" for low oil pressure. It threw me off too. Hope this helps.
Ray A.
Ray A.
tempestv8 (03-17-18)
