Spacers on F-Sport
Below are the shots of my rear with the new 20mm spacers. I almost wish I had went with 15mm and then wider tires. I get the impression, at the moment, that if I go with wider tires at this point that the fronts will actually be a hair outside the wheel well. I'll stick with what I have, though.
The cons are that they were more money than I would have preferred to pay, and my wife initially did not like them, but she is now ok with them as she has gotten more used to the vehicle.
Pete
I have the 20mm spacers with 8 inch wide 19 inch wheels and 255/50/19 Goodyear Eagle Asymmetrical All Season Tires. The Goodyears are pretty wide for their size and stick out past the wheel which is great for curb protection, traction and a more aggressive look. They are great tires.
Using Clutchless's setup, and comparing it to my (still stock) setup, I get the following:
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
In the above diagram, I used 20mm for the fender clearance, when in reality, 20mm is to the OUTSIDE of the fender. The actual clearance is less. Ignore the suspension clearance and wheel wells clearance, as I didn't enter anything here so the website went with default. I will get better numbers for these in the future.
The settings for Clutchless's setup is on the right. Note that the offset is set to 25mm which accounts for the +45mm of his wheels plus the 20mm spacer. This calculator implies that there is not enough room for the tire with 20mm spacers, and the wider wheels. The fender clearance became interference and disappeared from the diagram. The calculator assumes the stock setup has zero scrub radius, though in reality, its probably negative. What's more important is the delta in the scrub radius the new wheels and spacers give you. With the IS-F front wheels at 19x8 and 45mm offset with 20mm spacers, scrub radius is increased by 10mm. As Macpherson strut suspension systems typically have negative scrub radius (which works better with this type of suspension), reducing the scrub is not a good thing.
I suggest using 10mm spacers if running wheels with 45mm offset.
The replica IS-F wheels I purchased had the same 35mm offset as stock wheels. Maybe the 45mm offset you assumed is what OEM IS-F wheels have.
I do not have any rubbing issues with this setup.
They appear to no longer be available from the place I bought them but I found them elsewhere online in a different color - see this link as it shows the 35mm offset
https://stockwheelsolutions.com/whee...set-of-4-19x8/
PRODUCT DESCRIPTION
Fitment:
Fits: Lexus ES 1992-14, GS RWD 1993-14, HS 2010-12, IS 2000-14, LS 1990-06, RX330 2004-14, SC 1992-10, Toyota Avalon 1995-14, Camry 1992-14, Matrix 2009-13, Prius V 2012-14, Sienna 1998-14, Rav4 1995-14, Scion TC 2011-14, Scion XB 2008-14. Fitment guaranteed for Stock Equipped vehicles only. Does NOT fit vehicles equipped with upgraded or performance brakes such as Brembo.
Color: Gunmetal
Offset: 35mm
Bolt Pattern: 5x114.3
Center caps: Center cap shown included, (factory center caps will interchange)
Brand: Replica
Hub Size: 60.1
PRODUCT DESCRIPTION
Fitment:
Color: Gunmetal
Offset: 35mm
Brand: Replica
Hub Size: 60.1
You are correct, I assumed the IS-F replica wheels you are running would match the offset of the OEM IS-F wheels. Good to know the offset is actually 35mm instead of 45mm. That makes a difference to the resulting scrub radius. At 35mm offset, with 20mm spacers, the scrub radius is increased by 20mm.
Have you noticed any adverse affects to your handling, such as darting under heavy braking?
Good to know you don't have rubbing. The numbers I put in the calculator above are a first stab at the analysis, and I will be refining them. The front fender lip of the 3RX is mostly covered by the plastic inner fender liner, and the car (in stock form) has a ton of wheel well clearance, compared to cars. I will need to account for that.
My goal would be to match up new wheels to wider tires - possibly the same 255/50R19 you are running. I really like the stock OEM 3RX wheels I currently have as far as the spoke pattern goes, but of course, these wheels don't come wider than 7.5 in. I have the 15 spoke or triple split 5-spoke (2013 version) or whatever you want to call it.
I like the look of the IS-F spoke pattern, like the wheels you are running, so they could work for me. I am going to look into seeing if the 19x9 version will fit the 3RX and not hit the strut or anything at the rear of the car. I am going to take more accurate and detailed measurements. Side note, I have an AWD 3RX, non F-Sport.
The site you linked to seems to be out of stock on those particular wheels, at this moment. I'm not in a hurry. I have a few months before I need new tires, so I can delay buying new wheels until I need the new tires.
The handling is far better with the spacers and bigger wheels/tires than it was stock with the 18 inch wheels. There are no issues with darting under heavy braking. Steering is very accurate, partly due to the Goodyears which are known for sharp steering responses.
The later addition of Bilstein B6 rear shocks (which are really for the 2014 - 2018 Highlander) also improved the handling and ride. I only have Sachs sport struts in front because I was not yet aware of the Bilsteins but they are comparable although harder to find than the Bilsteins. Search this forum using Bilstein to learn more. Note that the Bilstein front struts are those for the 2011-2013 Highlander.
Doesn't even look like you have spacers on. I wanted to get some for my car as well. Heard you shouldn't get you wide of a spacer or else it'll cause issues. Not too sure because i've never had spacers on any of my previous cars
xtremex626
General Classifieds
01-31-17 02:35 AM
