Fog lights not working
2014 RX 350
Had a fog light go out driver side. At the time not knowing better and the auto parts store saying th H16 bulb crosses to a H11. I replaced both with H11 the ran for a little bit ( don't know ,I tested they worked, so I went for a drive come back 30 min later not working.
Replaced those with new H16 bulbs but now they do not work. Tested bulbs individually, and thy are fine. Fog light indicator comes on on panel, but they do not work.
Any ideas anyone?
Any ideas anyone?
Check your fog-light fuse and see if it is blown or not.
I believe that the h11 bulbs and h16 bulbs have the same 55w wattage ratings so using a standard bulb should not be the issue.
Did you use a bulb that had a higher than 55w rating?
skperformance
47
12-12-18 12:03 AM
