How do you turn the heater on?
IIRC, if you want warm air coming from the dash vents you will need to manually select them as the floor vents are used by default for heating.
Turning it up higher doesn't make the heater faster. It just changes the set point.
Paying for updates is the norm at any dealer. If you're on very good terms with your SA you might be able to swing getting one for free but that's an exception and not the norm.
