Replacement wiper blades with instructions (merged threads)
Old 08-02-21 | 02:36 PM
  #211
iolmaster's Avatar
iolmaster
Originally Posted by Merninater
I have been trying to track down the best wipers for 3rd Gen RX's. I have tried a couple types and have not been satisfied. My simple go-to rainX beam does not perform the best on this massive windshield and is susceptive to jitter even on cleaned windshield. Does anyone have a good recommendation that isn't extremely bulky? I had a nice set of bosch once on another car that I loved but I cannot seem to find them in-store for RX. I would even consider buying OEM if that is best.
the OEM is nothing more than the Denso low profile blade. Available on Amazon. Or just do as the last poster said and refill the original OEM blade if you still have them. (probably not)
Here is the one for the drivers side.
Amazon Amazon
Old 10-10-21 | 10:03 AM
  #212
jms123's Avatar
jms123
Just installed new rain-x latitude wipers. The passenger side is streaking. Is this indicative I received a bad product?
Old 10-10-21 | 02:30 PM
  #213
Clutchless's Avatar
Clutchless
Try cleaning the windshield and wiper blade before returning it to the store.
Hayk (10-10-21)
Old 10-10-21 | 08:57 PM
  #214
Hayk's Avatar
Hayk
https://www.amazon.com/Denso-160-312..._t3_B002Y30HPY
This is correct, however I found that the dealer charges less for the wiper blades than Denso on Amazon or RockAuto. You just need to shop around and have the part number.
Old 10-11-21 | 05:32 AM
  #215
RX in NC's Avatar
RX in NC
I purchase the wiper blade inserts at the local Toyota dealership parts counter. Least costly way to obtain them in my neck of the woods.
MellonC00 (01-02-22)
Old 10-11-21 | 08:25 AM
  #216
jms123's Avatar
jms123
the Toyota dealer carries Lexus parts?
I had them put blades on a long time ago and they sucked
What do you suggest cleaning the new blades with?
Old 10-11-21 | 09:46 AM
  #217
RX in NC's Avatar
RX in NC
Lexus uses the same wiper blade inserts that Toyota does.
You can clean the rubber inserts with soap and water, isopropyl alcohol, dishwashing detergent, or any number of cleaning agents. Just take your time and be gentle with them. I use dishwashing detergent and an old cotton washcloth, then rinse them with water. Works for me.
Clutchless (10-11-21)
Old 10-11-21 | 09:59 AM
  #218
jms123's Avatar
jms123
These are for brand new blades. I was complaining that the passenger side was streaking. I'll give it one shot to clean the windshield and then wipe down the rubber but if it still streaks I am contacting RainX or Amazon for a replacement. For all I know someone could have used it, put the protector back on and returned to Amazon, and they resold
Hayk (10-11-21)
Old 10-11-21 | 01:55 PM
  #219
RX in NC's Avatar
RX in NC
I quit using the Rain-X windshield treatment liquid product 15 or 20 years ago because I did not like the pesky multicolored film it always left on the factory-tinted exterior glass regardless of how many times I attempted to clean it off. For that reason, I never tried the Rain-X brand of wiper blades on any of our vehicles because I assumed they were permeated with the Rain-X product and I did not want to go through that hassle again. Perhaps this is what is creating your current windshield streaking issue.
Old 10-11-21 | 03:53 PM
  #220
jms123's Avatar
jms123
Driver side is perfect, just passenger side - now I got TLC stuck in my head "Hangin' out the passenger side of his best friend's ride."
Hayk (10-11-21)
Old 01-01-22 | 06:40 AM
  #221
vinster29's Avatar
vinster29
Default recommended brands for rear wiper blade replacement
Hi everyone,
I recently tried to replace the rear wiper blade in my 2011 Lexus RX450h with a Michelin wiper blade and I was unable to find the appropriate connector to use for the new blade, I was wondering what wiper blade brands are recommended for replacing the OEM rear wiper blade?
Old 01-02-22 | 08:27 AM
  #222
Clutchless's Avatar
Clutchless
You may find that getting a replacement insert at a Toyota or Lexus dealer is easier. They are on eBay for $7.50
https://www.ebay.com/itm/25355259933...YAAOSwuGZazKzw
You can also find aftermarket rear blades on eBay by searching Lexus RX350 rear wiper blade
However, this Anco blade at RockAuto is supposed to fit
​​​​​​https://www.rockauto.com/en/moreinfo...t=8852&jsn=862
Old 09-11-22 | 07:55 AM
  #223
gsu13's Avatar
gsu13
5th Gear
I think I read through this whole thread and did not find this answered. Can anyone confirm the difference between replacement 85222-52170 (~$30 on parts.lexus or cheaper at some Toyota dealers) versus the 85222-YZZ18TM (~$11)? Is the -52170 actually the Denso or factory one and the -YZZ18TM is the Sightline, budget value one?
The right, passenger side 85212-0E020 doesn't seem to have a YZZ equivalent nor a Toyota equivalent. I think the Venza 22 inch might be closest after searching for the refill 85214-0T040 and finding 85212-0T020 (a "T" vs an "E"?) I realize the inserts/ rubber refills are in an earlier post (see below) and am looking to just do refills going forward but the original blades are gone and not sure the Sightlines take refills.
Update:
My local Toyota dealership parts department does indeed sell just the wiper blade rubber refills for $9.99 each. The driver-side 26-inch refill is Toyota part no. 85214-0T050, and the passenger-side 22-inch refill is Toyota part no. 85214-0T040. I will grab a couple pair of these refills before the prices go up in 2019.
Old 09-11-22 | 08:09 AM
  #224
Randyp1234's Avatar
Randyp1234
I've never analyzed the exact part numbers. I've just ordered these.
Old 12-05-22 | 09:30 PM
  #225
WolfyLS460's Avatar
WolfyLS460
I've just replaced my wiper blades with these. Couldn't be happier --
BOSCH ICON BEAM Wiper Blade (26A + 18A pair)
$60 from ebay
They're rated #1 by youtube reviewer Project Farm,
Cheers,
