Replacement wiper blades with instructions (merged threads)
As mentioned by the OP you can go to rockauto.com as an example. To save yourself shipping charges you might try your local auto parts store (Advance Auto Parts, AutoZone, O'Reilly Auto Parts,...) to see what they have in stock. While the Amazon.com prices may seem a bit high you need to keep in mind that you will not be paying any shipping charges, assuming you are buying direct from Amazon and not from one of their vendors, on the order. Most other places you will pay a fee if you have them shipped.
I am OK with the price as you are getting the whole blade assembly, not just the rubber part. They are definately a premium product IMHO, so a little more expensive, just like everything else on our Lexus' ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Moderator: "Move to Best replacement wiper blades?" thread if you wish. Sorry, I didn't see it, was before my time.
I used Valeo on my other cars and I typically get about 2 years life out of them. I would buy them from Tirerack and get their buy one get one free special so I only pay $20. While the Valeo is thin, low profile blade I still prefer the look of the OEM blade.
I have tried different blades for RX in the past 4+ years but I am back to using the oem. I saved the OEM blade holder just in cases I wanted to refit the OEM and I am glad I did. OEM does really good in heavy snow [remember the snow of 09-10 winter?] and in higher speed condition.
Trico Teflon Shield blades are allegedly the OEM blade. I got some at Rock Auto for about $4 on their big distributor close out (they are in relabeled packaging). They look just like the OEM blades. They work well so far.
blade holder probably is more important since 26 inch is fairly long and will require more "pressure" points to give equal swipe. OEM holder also performed really good in heavy snow like a winter blades with rubber cover.
tonyro56 (11-10-21)
tonyro56 (11-10-21)
My OEM blades flutter at the bottom end of the driver's side blade. They don't make a nice smooth swipe. But then I only used them for the first time a couple of weeks ago. I have had the RX since January. It is pretty arid here and we rarely need them, and we carpool a great deal of the time in another vehicle so the RX is mostly only driven on weekends. I was thinking about trying the Trico or Bausch blades. It sounds like many of you have tried some of those other brands and tend to prefer the OEM blades. Now I am thinking perhaps I should give those OEMs another try.
Why would you want to switch out the OEMs in the first place? I have found the OEMs do a really nice job of clearing the window and when they start to streak I can stop in with my Lexus dealer and pick up a new set of inserts for less than what you guys are quoting here for new aftermarket blades.
This one is for the books. I regularly wash my 2010 RXh and when I do, I clean the blades with the wash mit and rinse them while they're up in the air. I also keep the car in the garage. FWIW, I am still getting good use of my original blades with 55K on the car both front and rear.
I'll probably change them in the spring just because they're 'old'
Definitely one for the books, Cruiter. You are doing it right. Cleaning with regular soap and water on a regular basis is not only good for the inserts but also for your windshield.
