iPhone 6 iOS9 bluttooth music?
I've been having issues getting the music on my phone to play via Bluetooth. I did get it to work once, but don't recall what I did! My phone is connected, I can make calls, it says audio is also connected, but when I try to play anything the playlist is blank. Is anyone else having this issue? Is there a trick? The Enform apps are working, just no audio. I searched this forum, but all references are quite old with older versions of iOS.
Thankd
Thankd
I use android but the setup should be similar. Usually when you connect the first time you have to give several permissions for access to messages, phonebook, music. Could you have missed one of these?
I would suggest disconnecting the phone and remove the pairing in your phone then try pairing again. The Bluetooth is quirky and does not resolve problems well. I have a Bluetooth enabled landline phone in my house. If it doesn't disconnect from my phone before I start my Lexus in the garage, my RX will not pair because it gets the passcode wrong. removing and re-pairing is the only thing that works in that situation too.
I use android but the setup should be similar. Usually when you connect the first time you have to give several permissions for access to messages, phonebook, music. Could you have missed one of these? I would suggest disconnecting the phone and remove the pairing in your phone then try pairing again. The Bluetooth is quirky and does not resolve problems well. I have a Bluetooth enabled landline phone in my house. If it doesn't disconnect from my phone before I start my Lexus in the garage, my RX will not pair because it gets the passcode wrong. removing and re-pairing is the only thing that works in that situation too.
Hadn't till a moment ago! Seems to work that way. Is that a step I missed, or is there something funky going on? I've had the music app open before and it wouldn't connect. If I have to start the playlist from my phone, I guess I can live with it, but kinda inconvenient, if I forget to do so, before settling off, but better than what I've been experiencing thus far.
