Manually opening the rear door
Old 05-09-16, 10:35 AM
steerpike
steerpike's Avatar
Default Manually opening the rear door
I'm sure I'll appreciate the electronic lift on the rear door at some point, but most of the time I'd prefer to simply lift the door, perhaps saving the motor as an added benefit. But I can't seem to 'cleanly' do this. I've read the manual a few times. In order to manually open the door, it says you press on the leftmost button on the door itself. But this seems to initiate the motor lift.
I don't want to fully disable the feature (using the switch in the glove compartment), just manually override it when desired.
Currently, it feels like the motor is kicking in and then I'm overriding it, which makes me worry that I'm going to do some damage. Am I doing something wrong? Thanks!
Old 05-09-16, 11:05 AM
NateJG
NateJG's Avatar
With the car locked, quickly double-clicking the button above the license plate will cancel the motor assist for that opening.
Old 05-09-16, 03:09 PM
steerpike
steerpike's Avatar
I just went out and played with this ... seemed to work the first time, from locked. I then tried with the car unlocked (for me, 99% of the time the car is going to be unlocked already when I want to open the rear) and it seemed to work 'half the time'; a fast double-press would generate a single 'beep' and you could hear the 'latch' release, and the door would open a fraction, then I could lift manually. But the other half of the time, seemingly random, the door would open on the second press. Is there a technique I need to master?
Thanks!
Old 05-09-16, 04:36 PM
NateJG
NateJG's Avatar
You need to a) cross your ankles, b) use your left hand, c) ensure it's not raining, and d) pray.
You caused me pause - I try not to post something without being able to substantiate it - and I was so sure of my post that I didn't do the research. See:
Well, just interrupted Wifie's viewing of "Castle" three times to run to the garage to try and make my car open per the above - and I can't!
On my car ('13 RXh), I simply double-push the button - and then lif the gate manually. Works that way for me regardless of whether or not the car doors are locked.
I cannot get it to work as the manual (above) instructs.
Go figure.
Old 05-09-16, 07:48 PM
steerpike
steerpike's Avatar
Go figure.
I wonder if it detects your movement of the door and self-cancels the motor? I believe it's designed to stop if it hits any obstruction, right? so your 'pulling' it is perhaps detected as something 'not right' and thus it stops.
To be pedantic, do you press and release twice, then lift on the frame, or do you press once, release once, press second time and then keep pressing/lift the door in one continuous flow?
Old 05-10-16, 05:05 AM
NateJG
NateJG's Avatar
Twice - quickly - before the motor starts.
Your mileage may vary. Some exclusions apply. Not intended for unlicensed drivers. Avoid running with scissors. Etc.
Old 05-10-16, 08:44 AM
Clutchless
Clutchless's Avatar
Received 1,193 Likes on 1,020 Posts
I press once as I lift to open manually. I am pulling on the door as i press the button. Maybe that over-rides the motor. Maybe my old 2010 operates differently.
Old 05-10-16, 11:39 AM
User 41924
User 41924's Avatar
You can defeat the motorized opening 100% of the time by having the dealer change the preference setting (sometimes they say they can't do it, but they can). My wife prefers the automatic opening, and won't let me "fix" it. I just open it by pushing the button on the tailgate twice. It doesn't have to be particularly quick. Just twice. Works every time. Much faster than the automatic, too. It drives me nuts to stand there and wait for it to open.
Old 05-10-16, 01:06 PM
steerpike
steerpike's Avatar
Originally Posted by Woodrow
You can defeat the motorized opening 100% of the time by having the dealer change the preference setting (sometimes they say they can't do it, but they can). ...
According to p. 85 of the manual, 'Canceling the power back door system' - 'Turn off the main switch in the glove box to disable the power back door
system.
So you should not have to have the dealer involved, at least!
Old 07-02-16, 12:19 PM
steerpike
steerpike's Avatar
... I just open it by pushing the button on the tailgate twice. It doesn't have to be particularly quick. Just twice. Works every time. ...
For what it's worth, after several months of ownership, I've found three quick presses of the rubber button above the license plate in succession do it for me - 3 full press/release cycles. The door moves a bit (I think this is the 'release'/'unlock' phase, and a beep is heard, but no attempt to 'lift' the door is felt). I can then pull up on the door with no issues. I tried one press, and two presses, but never got consistent results. It could be that the third press is entirely wasted, but this is now my standard practice and it works every time. Happy!
Old 07-03-16, 04:06 PM
raylor4
raylor4's Avatar
Hilarious! We think alike.
Ray A.
Old 07-05-16, 12:26 AM
TheSnowman
TheSnowman's Avatar
Ray A.
Both of you probably listen to George Carlin
troz350
10-08-20 08:01 AM
NXOwner
NX - 1st Gen (2015-2021)
09-11-15 11:24 AM
mickeymel
09-19-12 05:19 PM
09lx570CC
LX - 3rd Gen (2008-2021)
09-03-08 03:08 AM
rx330modde
01-28-06 02:58 PM
Quick Reply: Manually opening the rear door
