RX350 2010/2011 Air conditioning DTC B1479 cheap solution
#152
It is unclear what you are trying to articulate or what you cannot find.
Start reading around post 80 and higher for info on placing the magnet etc with photos.
The photos etc are repeated around post 143 +
#153
again same misguidance. Magnet is only temporary solution, not removing issues. It is same as you try to make girl smile while pooling by hair braid.
To fix issues - you should not cheat sensor, but fix it, clean it. I have done it without changing sensor. Flow speed is important for calculating how much to open control valve, how long to keep fan speed on higher or lower rpm.
#154
When you're in a fix you'll realise the need for the cheapest "misguidance" solution.
#155
Cheers!
#156
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
It's a flat magnet; flipping it changes the polarity. What pole does the trick, I don't know. Simply flip the magnet and see which side works.
There's a snap ring that holds the sensor in place. Stick the magnet to the ring. Mine has stayed there ever since without falling off.
#157
Please have a look at the video, which i posted above. There is clear information, how to clean all flow sensors system, not only a sensor, but also thing, which is giving signal to that sensor. This work can be done while removed compressor. No need to open all compressor, only small cover below flow sensor. Clean that hole, clean area down flow sensor, fix it properly and you will not need to cheat flow sensors value to switch on system by force. System has to be in harmony - all sensors has to have exact information about values from sensors. Otherwise it will work bad. I have gs350. I had problem with flow sensor values. I removed compressor, cleaned it and values were fixed. Sensor started to show exact information. There is nothing what can be damaged in sensor. It just goes away from exact place, where it must be. Rust lifts it on 0,3 mm. Distance is very small, but sensors magnetic piston inside compressor is moving 2mm up down, so this small distance affects values very much. But as I said, the way with additional magnet is wrong solution.
Cheers!
Cheers!
Here is what I did....2013 Camry 4cyl(sorry, no pictures taken during the process).
Removed the fans/radiator(for easy access to the sensor. Perhaps removing the fans alone will do).
Once those two were out of the way, working on the compressor/sensor was easy(no need to remove compressor).
The sensor wouldn't come out in one piece so I broke it off into pieces. Used sharp penknife to pry the remaining base out. Once the knife was under the sensor base, the remaining piece lifted out.And yes, lots of debris had formed/accumulated underneath the sensor. Scraped it all out. Placed another sensor(from AliExpress) in the groove(completely easy to lay down.... No force needed).While holding down the sensor, I used "modified acrylic adhesive glue" to hold down the sensor and cover the entire area around it(To keep debris away... Hopefully) any other strong adhesive should work fine.
NB:Wrap up the connection side of the sensor before applying adhesive, else it will drain down and make connecting the socket difficult.(Don't ask me how I know)
#158
Hi guys please I need y’all’s help.. My 2012 Camry ac won’t get cold no matter what I try!! Bee told to replace compressor and condenser 🤒🤦♂️, saw the magnet fix which I tried the ac came on cold for about 3 mins and it went back blowing just air… can anyone please help me don’t have about $2000+ for the fix from Toyota and other side mechanics want to change the whole ac system from auto to manual 🥺🤦♂️
#159
Hi guys please I need y’all’s help.. My 2012 Camry ac won’t get cold no matter what I try!! Bee told to replace compressor and condenser 🤒🤦♂️, saw the magnet fix which I tried the ac came on cold for about 3 mins and it went back blowing just air… can anyone please help me don’t have about $2000+ for the fix from Toyota and other side mechanics want to change the whole ac system from auto to manual 🤦♂️
The magnet trick is cheating of the system, is only temporary solution, while driving home from far. That sensor, which we cheat with magnet is involved in calculation algorithm how much gas needed to reach required temperature. When value is wrong - all system will loose harmony.
#160
Hello... I have a 2013 rx350.... same intermittent AC issues ... having trouble finding the AC Flow sensor under the hood... Is it on the right side while looking under the hood? Can anyone advise how to access this sensor so I can try the magnet temporary fix? Thanks so much!
#161
It has been quite a while since I have read through this thread but if I remember correctly, you access the HVAC flow sensor by raising the vehicle on jack stands and then crawling underneath it.
