Is there a way to upgrade the reverse camera
Old 09-12-17, 10:58 AM
vlad_a
vlad_a's Avatar
Technically speaking, 3RX did feature guidelines. Just not for USDM. For whatever reason, that feature was not intended for our market.
Old 09-12-17, 11:06 AM
MellonC00
MellonC00's Avatar
Blame the Yen/Dollar exchange rate. they gotta make it up somewhere....
On a more relevant note: Does anyone have the JDM camera installed? Any pics?
Old 09-12-17, 02:28 PM
Airbalance
Airbalance's Avatar
I have a hard time backing the RX when I use the camera
Old 09-12-17, 05:46 PM
salimshah
salimshah's Avatar
Received 1,045 Likes on 943 Posts
The Eruo and Asian model of the same years have the yellow lines ... not sure if they have the blue/grey steering wheel coupled lines or not.
Salim
vlad_a: Do you know the part number for the Camera _ECU of non USDM? I am almost sure the grids are part of the ecu and not the camera.
Old 09-13-17, 06:24 AM
vlad_a
vlad_a's Avatar
Salim, I'm fairly certain it is an overlay from ECU as well.
I have guidelines in my Audi, but I don't really care for them. I don't even notice that they turn with the steering wheel.
I use two side mirrors and the camera to back up.
Old 09-18-17, 04:04 AM
YankinDeez
YankinDeez's Avatar
Default Upgrading to Nav?
So if you don't have a Navigation system, and manage to buy a used one for your make/model, and install it, will the backup camera transfer to that? Is there any way to make that happen?
Old 01-22-18, 08:46 AM
Earline9
Earline9's Avatar
Default Grid lines
I have a Lexus 2014 RX 350 can grid lines be added to the back up camera?
Old 01-22-18, 09:34 AM
Clutchless
Clutchless's Avatar
Received 1,158 Likes on 988 Posts
No that is not possible. And welcome to CL in case you ever post again.
Old 01-22-18, 09:35 AM
mcomer
mcomer's Avatar
No they can not be retrofit to the 2015's and earlier RX's.
Old 01-23-18, 12:27 PM
riredale
riredale's Avatar
Just as an aside, the fact that an identical car sold in Europe might have backup lines while the car sold in the USA doesn't is probably due to patent licensing issues.
As a somewhat-similar example, the Canon inkjet printer model (IS3000) that I've used for many years is quite sophisticated. It can auto-duplex (automatically print on both sides of the paper) and also print on CDs/DVDs. But the US printer has a plastic bar across the front slot where the disk would go. Why?--Because Epson held the patent back then for disk printing for the US, blocking Canon from offering that feature.
In this case, the solution was relatively simple: just take off the plastic bar and reload the US printer with the firmware meant for Canadian or Australian-bound printers. Been working great for years.
FatherTo1
07-21-16 10:32 PM
RookieLEX
ES - 5th Gen (2007-2012)
06-29-16 02:43 PM
bscottj
GX - 1st Gen (2003-2009)
09-12-04 10:39 PM
Quick Reply: Is there a way to upgrade the reverse camera
