Estimated Costs for replacing Front Struts and Rear Shocks?
OK, the car now has 180k miles on it, at nearly 7 years old. The latest service showed the tires are cupping, indicating time to replace some suspension components. I asked for an estimate, and I was told:
$950 for parts and installation of front shocks
$550 for parts and installation of rear struts (or vice versa, I can never remember).
I have had the notorious squeaking in the passenger rear, that numerous members confirm are the rear trailing arms. Is this included in the parts for the struts, or is it a whole 'nother part and installation cost? And even if not included, what would the cost be of those parts too? $1500 for the suspension plus a new set of tires (I'm due for a new set) is a real hit to the wallet...
Are there sources where I can buy the parts myself, to make sure they're what I need (rather than some cheap knockoff part?)
Rear shocks took me an hour in my own garage with a floor jack & torque wrench. All tools were manual. The hour included a spin around the block too.
I used OEM shocks about 70.00 each. $550.00 for the rear set sounds pretty rich.
Front struts will take a bit more time but not a major job. I've changed a few on Civics using spring & strut assemblies. I'm guessing about an hour each side.
$950 sound rich here too.
Rear arms are another animal.
Struts in front, shocks in rear. The rear trailing arms would have nothing to do with a shock replacement, so count on extra $$ if you want to do those as well. There are some other threads that mention the cost of the rear trailing arm replacement, a search might pop something up.
I'm kind of surprised based on "tire cupping" they suggest struts and shocks. I would have suspected other suspension components first. I've had struts and shocks go on cars before and never saw it affect tire left (my +13 year old Sienna with 220,000km still has 1 original strut and both original rear shocks and tire life is still excellent, even though the ride quality certainly isn't like new anymore). You can go with non-OEM parts, probably cut the cost of the parts in half, but ride quality might be different and also might not have the same longevity.
Rear OEM shocks are 44.86 list price ,trailing arms are 330.00 a side . front struts are 157.00 a side .there are other parts on the struts that sometime need replacing also. Any good independent shop can install these parts and do an alignment cheaper then dealer .
With that high a mileage, when replacing the front struts you also want to replace the strut mount bearings, which are about $30 each at www.lexuspartsnow.com or one of the other online discount OEM sources. I agree with those above that it will be far cheaper to get the OEM parts yourself online, or price them through an independent as they get a dealer discount and have the independent garage install everything as you will save a lot of money. I have found the OEM shocks and struts to be cheaper than the only aftermarket source, KYB, who also makes the OEM ones. I just ordered rear shocks for $33.90 each from the above source because mine were leaking. With shipping it was about $40 each.
When shopping recently for my rear shocks, I noted that Lexus Parts Now lists the Sports Package shocks/struts for my Canada built vehicle and they are the same price. Pay attention to part numbers because Lexus has changed them a couple times but they cross reference, you just have to be diligent. I also looked at Lexus South Atlanta where they list the Sport Package shocks (2010-2012?) as no longer available. Note the Japan built vehicles take different part numbers.
I also looked at this Austin Lexus dealer online because another thread on CL advised they had an extensive detailed parts listing. They indicate the Sports Package shocks are available.
http://parts.autonationtoyotasouthau...omponents-scat
Both Canada built rear shocks are the same part number. Left and right are the same part.
The Sports Package rear shocks are part no. 48531-0E141 which replaced 48531-0E040 and 48531-0E140.
The Regular Base rear shocks are part no. 48531-0E130 which replaced 48531-0E020
My replacement rear shocks arrived and are made by Tokico! Will post photos when I do the swap.
Replaced the shocks and found that both the original and replacement shocks are made by Tokico. Both of my rear shocks were leaking, with wet lower shock bodies. I wonder why Tokico does not then make aftermarket shocks for the RX. I found a youtube video of the replacement, so did not take any photos.
Shocks x 2 = $90
Trailing arms x 2 = $660
Struts x 2 = $314
Total: $1064 plus labor. Knowing that I got finally got the trailing arms fixed would be a good thing - the rear squeak has annoyed me for a while :-)
Fantastic, thank you!
Anita, yes, I know that the sport versions are stiffer, and this post by Clutchless is awesomely helpful.
When shopping recently for my rear shocks, I noted that Lexus Parts Now lists the Sports Package shocks/struts and they are the same price. Pay attention to part numbers because Lexus has changed them a couple times but they cross reference, you just have to be diligent. I also looked at Lexus South Atlanta where they list the Sport Package shocks (2010-2012?) as no longer available.
Both rear shocks are the same part number. Left and right are the same part.
Clutchless, I just searched both the autonation site and the LexusPartsnow site, and neither showed a PN of 48531-OE141
I can drill down by rear springs/shocks, and then I get a lot of part numbers, none of which are clearly the ones I need.
http://www.lexuspartsnow.com/Page_Pr...=&PartNumbers=
That is because you have a Japan built vehicle, which I determined because you entered your VIN. I have a Canada built vehicle. They take different parts.
I will revise my original posting. However, under the listing for the Canada vehicle, it clearly states with Sports package for the appropriate shocks.
The Austin dealer I linked in above, has the shocks for both Canada and Japan on one page which makes it easier to see the part numbers for comparison. I think you may need to call them to figure this out.
https://www.youtube.com/watch?v=3xE_M6mOUz4
I did both upper and lower at 80 ft. lbs. which were the numbers I found for another Toyota model and figured it was likely the same on the RX. Anyway, that is close enough to your numbers.
Also I installed the Sport Package rear shocks on my vehicle and really enjoy the improved driving dynamics! No more body wallowing around when I pull into my driveway or go around a corner. More precise steering response.
Before I bought mine I spent months trying to find a rare sport package but gave up. I learned both models have the same springs but the struts & shocks and VDIM are really the only performance differences, not counting the 19 inch wheels, which are on a lot of them without the sport package. I may have to change the front struts next year.
