Low tire pressure light won't come off
My light won't come off even after putting air in my tires. I need to go to work soon and will need to check the spare tire pressure to see if that's the problem.
My question is, do I need to get my spare tire out of the trunk or can I just pump it while it's in it.
I'm driving rx350 2010
Thank you
Thank you
No, I don't play soccer!
The full spare was dropped on the 3rd gen RX. So no sensor anymore. Maybe you were looking at the 2RX forum. dat dude brings up a good point. There might be a slow leak from the valve or something in the tire. Hopefully it was just the tire pressure being off enough to trigger TPMS.
TPMS in the tire send a signal to the master computer. Each TPMS runs on a battery. That battery eventually dies. I believe the battery only last for between 5 to 10 years. Some as low as two years....so that may be the problem.
I have a 2010 450h which displays which tire is low but I believe the 350 just has the low tire display.
Note: I have dedicated winter tires on wheels so I have to reprogram the main computer, each seasonal swap, with the different hex numbers.
Also I believe the batteries are not replaceable so you have to buy the whole unit.
gserep1
04-29-10 10:42 PM
