Rear Washer Fluid Reservoir?
Greetings!
I'm trying to refill the rear washer fluid reservoir on my 2010 RX450h. I've been looking, but I can't seem to locate it in any of the manuals or online. Here the heck is the reservoir and how do I refill it?
TIA,
taichi
TIA,
taichi
as far as i know the rear uses the same reservoir as the front. it only has the one bottle under the hood. unless the hybrids are different?
One bottle and a long hose to the back. My old 1995 Ford Explorer had a rear reservoir. I think it had the original fluid when I sold it in 2013.
One reservoir up front for the windshield, rear glass and headlight washers if equipped.
Can you hear a pump running under the hood while holding the switch on?
Rear pump pick up is slightly higher than the main front so it stops working
first when the fluid level drops.
Yes, I hear the pump running
Thanks!
