Transmission noise
Old 01-12-17, 10:59 AM
CAC1
CAC1's Avatar
Default Transmission noise
My 2013 RX 350 (owned since new and currently with 42k) has, I believe, the very same noise since it was darn near new. The noise sounds to me to be from the transmission. It occurs right at 1700-1800 RPMs WHEN UP SHIFTING under mild acceleration. this is the very same sound one of my old Chrysler's made under the same conditions. i found out that the trans had an external valve body so hearing it was easy. I have no idea if this is the same noise. It has concerned me though I never went to the dealer about it when it was under warranty. can anyone else validate this noise? Should I be concerned? Any help would be much appreciated. Thanks
Old 01-12-17, 11:21 AM
PETERPHAN8
PETERPHAN8's Avatar
Are you sure it is from the transmission and not the engine ?
Old 01-12-17, 11:51 AM
CAC1
CAC1's Avatar
I can only hear it @ said RPM and right when it is in the process of up shifting. I cannot absolutely rule out that it is from the engine.
MHB1535
RC F (2015-present)
15
08-05-16 01:26 PM
quaiduhm
SC- 1st Gen (1992-2000)
07-30-11 08:57 PM
Abear
GS - 1st Gen (1993-1997)
04-26-10 09:35 PM
redgs400
Performance
07-10-03 10:06 AM
Quick Reply: Transmission noise
